I just got this camera on Ebay and am SO happy with it...but I accidentally dropped it the other day, and the latch on the battery door apparently broke off. I can still use the camera, as the battery door still slides back into place and holds the batteries in, but it is not secure. Is there a way to purchase a battery door and put it on myself, and is it fairly easy to do?
Is it the battery door? or the small plastic post thats broken. There should be four of them. When you slide the latch there are little metal things that slide into place which secures the door. If one is broken I dont think there is much you can do HP no longer can fix these. If its just the door you may have a chance at fixing it as Steve was saying. Good Luck But check the posts to see if its them..
Unfortunately HP will not sell you a camera battery door. If you can find another camera that is broken with a good battery door you may have a chance.
To repair/transfer the new battery door, you will have to use a small jewerly store screw driver that you can buy at the dollar store and use it to push the door hinge bar to one side of the camera.
Then, pull the door hinge out but be careful not to lose the tiny spring that is installed in between the hinges. ( Make sure that you know and understand how to put it back the same way.) You can then pull the battery door from the camera.
Do the same thing to good camera. Practice on the broken camera first. The second time it should go easier for you. When you install the new battery door, push the hinge bar in all the way to one side of the camera. Hold the door to give you the proper alignment and then use the small screw driver to pry the hindge bar from the one side to make sure that it is equally in each of the black hinge connectors.
This worked for me. I was fortunate enough to find someone who had a broken HP MZ67 digital camera that had a "good" battery door. It took me about 30 minutes to complete the job. I hope this will help you. You can email me if you need more advice. I am a computer tech.
Steve ([email protected]).
I see you posted this in 2009. If you need a battery door e-bay may have it. I just looked and there are ones for M425 HP cameras
