GE egr3000ed3cc gas oven continuously turns on for 10sec and off
I have a GE egr3000ed3cc gas oven that continuously turns on for 10 seconds and then back off for 2 seconds. The the stove top and broil work fine. I don't know it its a temp sensor, valve, or control problem.
If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
motherhood.modernmom.com > Around the House > Home Appliances
Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
There is a safety device built into gas outlets to prevent the gas from running if it fails to ignite. It works by heat. If a valve is not heated enough then the main valve will not remain open. That's why many gas appliances ask you to leave a second valve open for as much as 30 seconds after igniting. These valves are highly reliable. It sounds like your appliance may not be warm enough. Try to run it on high for 5-10 seconds before you turn it down. To access the valves; pull all the knobs straight off first then try to remove the facing by the screws. A make & model would be helpful since there are many different configurations.
Usually, This means that either the touch pad or the oven control (also called
clock or ERC) is defective and needs to be replaced. If this fault code
cannot be canceled, replace the oven control (also called clock or ERC),
touch pad, or both.
HI, This seems to be another ERC issue. the temperature sensory circuit is malfunctioning. the oven will not operate while this condition exist within the ERC. This malfunction will allow your oven to over heat and may cause a fire. The second issue will be that the relay drive circuit is malfunctioning as well. If you cant cancel the error code and continue with normal usage, you will have to replace the ERC once more.
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit) If you have an "open" circuit, the ignitor is bad
If you use a multimeter, you can test the gas valve where the white and yellow wires connect is where your terminals for bake on that valve are. If you have continuity there, then check to make sure that igniter is wired ok.
yes it is normal . but i know your not the first to think its not , todays ovens are so tight , it only takes 10 seconds of heat to keep them at proper temp . it used to be that ovens where kept at a 3 degree sweep that is set at 350 turn on and up to 353 then off ,cool down to 350 and back on . this was a longer time off and a longer time on topday we keep to 1 degree ! 350 on to 351 off to 350 on and so on ....... so short berst of heat make for a more even oven ........ but i know i hate it too ! good luck
the problenm is in the ignitor. there is a possibly a break in the ignitor to where there is no continuity in. I would buy a new ignitor and then shut off the gas to the oven and replace the ignitor. That will solve your problem. Have a Merry Christmas and thank you for using FixyA!!
I just installed one in my house. I found that when you start the lower (gas) oven you need to turn the dial all the way on to 500*, push the knob in (you should hear the igniters clicking), then even when you see flames coming out of the burner, continue the ignition for 10 to 15 seconds. It should continue to stay lit thereafter.
