Question about Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
My hotpoint oven is not heating up but hobb and grill working fine is it the heating element?
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
If you have a HOTPOINTelectric Cooker or Fan Ovenwhich is not heating it could be one of the following problems.
1, If the fanmotor inthe back of the oven is going round and the temperature light is on (normallylittle red light), but there is no heat then you will probably need a new ovenelement, these are generally very easy to fit and readily available from ourwebsite these can be tested with a electric meter.
To gain access to the HOTPOINTelement youwill have to remove the back plate from inside the oven. Once removed you willsee the fan and element,if you look closely at the element you will probably see a small hole burnt in it where ithas blown. Sometimes however there is no evidence of a fault but the element is open circuitie: broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your HOTPOINTfan oven is getting warm buttakes a very long time to cook or is burning the food more on one side than theother, then you need to check if your oven fanmotor is working you will seethe blade turning fast if it is ok. if the element is heating but the fanmotor isnot blowing the heat into the oven then you need To replace the oven fanmotor is a little more expensive and a bit moreinvolved.
3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace your HOTPOINToven thermostat
4, A quite commonand easily overlooked answer is if your HOTPOINToven is not working at all ie:no heat and no fan then the chances are that someone has put the oven timer intoAUTO mode, simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 25, 2010
  • 3 more comments
  • seetas May 30, 2011
    Please can you help as my oven is not working at all, no switch coming on.
  • apart4u
    apart4u May 30, 2011
    this could be that your timer is on auto if not then this can be many faults including thermostat fault or switch gear, also check if the element is blown see my right up on this
  • adrian capota
    adrian capota Sep 13, 2014
    hi i have the same problem i checked and has power at the back of the thermostat and switch
  • adrian capota
    the timer is on manual,the switch is working
  • Jon Lamb Dec 02, 2015
    How to change the heater element herehttps://youtu.be/OFEjyrhHylU
  • Hotpoint Master
  • 3,463 Answers
F the fan is working o/k, then you need to replace the oven element located behind removeable cover at rear of oven compartment.
Please rate my solution.
Thanks.
Posted on Nov 15, 2009
6ya staff
SOURCE:
Hotpoint BD32 built in oven is not heating up anymore, top oven/grill works fine. When it's switched on it makes the right "noise" but there is no heat or light. Is this an element problem?
you can check the element, just get a volt ohm meter, set to ohm's and make sure it shows a short, otherwise you have an open or bad element.
Nov 06, 2013 | Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
Hi, I'm Housewife21. I have a NEFF B1420 Gas Hobb/Electric fan oven The grill and hobb are fine, however the oven has stopped working properly. The fan comes on but no heat is produced. Is this likely to...
Hi This will be an element replace. I can do for you if required depending where you reside. I cover every Midlands postcode, Coventry Walsall and surrounding areas . David on 078123047557
Oct 22, 2017 | Neff Ovens
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
My hotpoint ew61 double oven doesnt come up to
If it is heating, but not getting hot enough, then it is possible the thermostat is cutting the element off too soon, in this event, you will need to replace the thermostat.
If it is not heating at all , then the element is probably faulty.
Thanks.
Nov 14, 2009 | Ovens
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
6,151 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
