I have recently moved home and had to leave behind the lead going from my tuner box to my sharp plasma tv (model number lc-37hv4e) as it was plasterd behind the wall from when i had it fitted about 2 years ago.... i am having problems trying to purchase a new 1 so if any body has 1 for sale or could point me in the right direction i would appreciate it. please email me at the address below
SOURCE: Sharp Aquos LC-32D41U
The unit has bad drive ic's,which is part of the lcd panel.It is not cheap to fix.
SOURCE: need help programing a directv remote to a sharp tv, model # lc46sb54u
I know what you mean. :(
I couldn't get mine to work with my Emerson TV. No codes worked.
You may have a chance with yours. Try this link here to get and program the codes:
http://www.directv.com/DTVAPP/global/contentPage.jsp?assetId=P4350020#
Then if does control the TV, hopefully the input button on the remote will work.
SOURCE: Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Sharp LCD flashing red light and no picture
yes thats is a common problem for all flat tv not only
sharp ;/ first theres is capacitor in power supply
you probly have few one there blow up and it could bee from the power section of your back light circuit
a good technician can fix that easy
good luck
