Kodak es c875 flash works once then not again until you remove and put batteries back in
Try to do this press the flash button then chose the Fill Flash so if you take picture it will always fire the flash., May be your using the Auto Flash.
If your flash will not fire using the Fill Flash setup it means the Flash is defective call tech support toll free 1 800 235 6325 ext 12
You may also see the flash setting if you press the menu button and under menu button look for setup
