Lands Phones Logo
Posted on Nov 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Setting up your voicemail - Lands Phones
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2815
Points
I bought and Uniden Dect 6.0 phone and the other day I had a voicemail msg but I can't retreive it how can I do that the book doesn't show how to set up for voicemail
poisnscorp
Level 2:
Novelist:
  • Expert 111 Answers
  • Posted on Nov 15, 2009
poisnscorp
Expert
Level 2:
Novelist:
Answers
111
Questions
0
Helped
54401
Points
377
Setting up a voicemail greeting on your Verizon Wirelesssetting up your voicemail - mag-glass_10x10.gif cell phone takes just a few minutes of your time. If you're in a time crunch, you may want to write down what you want to record as your personal greeting. This way, you can simply read your greeting into your phone when Choose Your Password
  • To access your voicemail options, dial *86 on your cell phonemag-glass_10x10.gif, then press Send. If this is the first Verizon Wireless cell phone you've ever owned, you will be prompted to choose a four-digit password. Follow the prompts to confirm your password, then hang up. Upgraded Cell Phones
  • If this is a new phone that you've upgraded from a previous Verizon Wireless cell phone, your previous password and voicemail greeting will be stored into the new phone. You do not have to do the following steps unless you want to change your previously saved greeting. Main Menu Options
  • You can now test to see if the password you just created will work. Dial *86 once again. You will be prompted for your password. Enter the password you've just confirmed. Press the * key to access the Main Menu. You will hear a list of options to choose from. Press 4 to access your Personal Options. You will hear a new set of personal options which you can set up or change. Press 3 to record your voicemail greeting and name. Voicemail Options
  • Depending on how you wish to personalize your voicemail greeting, you have several options to choose from. Press 1 to record a personal greeting that all callers will hear if you do not answer their call. If you'd rather not leave a full greeting for callers, you can Press 3 to simply record your name. Press 1 to begin the recording process for your voicemail greeting. Recording Your Greeting
  • You will be prompted to choose whether you want to implement a pre-recorded greeting (Press 1), pre-recorded greeting with only your recorded name personalized (Press 2), or a full personalized voicemail greeting (Press 3). Press 3 to choose the last option to begin recording your full greeting. You will then be prompted to start recording your greeting. Immediately after you record your greeting, press the # key. The message you just recorded will replay. If you want to change it, press the * key. You will once again be prompted to begin recording. Continue pressing the * key and re-recording your greeting until you are happy with what you recorded. Press the # key to save your greeting
  • prompted to record it
    I have a VTech 6929 Phone system. I have tried everything in the manual instructions, but I cannot set up my mail box. I had it previously, and somehow it is gone. Can you help?
    Question edited for clarity.
    This phone system has two features.
    Answerphone system which records messages to the unit.
    and
    Voice Mail System which is an extended (often paid) service from your telephone provider.
    Sometimes a glitch at the Telcom will remove your Voice Mail. You will need to phone their customer service number and ask why they stopped the service you previously enjoyed? They will be able to put it back in place.
    Page 32 refers
    https://cdn-media.vtechphones.com/products/CS/CS6929/CS6929-X_WEBCIB_V3_20160224.pdf
    Retrieve voicemail from telephone service Voicemail is a feature available from most telephone service providers. It may be included with your telephone service, or may be optional. Fees may apply.
    Retrieve voicemail When you received a voicemail, the handset displays New voicemail and . To retrieve, you typically dial an access number provided by your telephone service provider, and then enter a security code. Contact your telephone service provider for instructions on how to configure the voicemail settings and listen to messages. NOTE After you have listened to all new voicemail messages, the indicators on the handset turn off automatically.
    Set your voicemail number You can save your access number on each handset for easy access to your voicemail. After you saved the voicemail number, you can press and hold to retrieve voicemail. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Voicemail #, and then press SELECT. Use the dialing keys to enter the voicemail number (up to 30 digits). Press SELECT to save. You hear a confirmation tone. • 1. 2. 3. 4. 5. 33
    Turn off the new voicemail indicators If you have retrieved your voicemail while away from home, and the handset still displays the new voicemail indicators, use this feature to turn off the indicators. NOTE This feature turns off the indicators only, it does not delete your voicemail messages. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Clr voicemail, and then press SELECT. You hear a confirmation tone.
    Set up voice mail
    It's easy and you can follow below steps.
    you can set up Voicemail and then record voicemail message by following these steps:
      1. Tap on Phone > Voicemail;
      2. Usually, you will be guided to automated voicemail system and you can simply follow voice prompt to set up Voicemail. If not, you have to follow these steps:
      a. Click "Set Up Now". You will be required to enter password. Tap password and then click "Done". Re-tap again and click "Done". Please keep in mind that password should be between 4-6 digits in length.
      b. Click "Custom" to record voicemail. Activate "Record" to start recording and tap "Stop" to finish recording voicemail. After you finish recording voicemail, tap on "Save".
    how-to-record-a-voicemail-on-iphone-eotioun5s4qsaaff3yzmdxjb-2-0.jpg For more details, check: How to Record a Voicemail on iPhone
    How do I retrieve voicemails? I have not set up voicemail yet.
    If you haven't set up your voicemail yet, then there s no voicemail to retrieve. The mailbox will not accept calls until you set the mailbox up.
    Set up voicemail on iphone5s
    It's simple. Just follow below steps.
    To record voicemail on iPhone, you have to first set up Voicemail and then record voicemail message by following these steps:
    1helpful
    How to turn off voicemail on samsung s4
    To turn on voicemail on s4 go to settings then open voicemail settings. Here you can change the voicemail settings
    Nov 16, 2013 • Cell Phones
    How do I set up voice mail on an iphone
    Adding Voicemail for the First Time
    1. Tap the "Phone" button on your iPhone.
    2. Select "Voicemail." The iPhone will prompt you to create a password for accessing your voicemail, then will allow you to record your first greeting.
    3. Click "Save" to set your recording to your voicemail greeting
    Recording a New Greeting
    3. Choose "Greeting > Custom."
    4. Select "Record" and begin recording your voicemail greeting.
    5. Hit "Save" to set your recording to your new voicemail greeting
    How do i set up my voicemail?
    According to the manual you have to subscribe to your telephone service providor to set up voicemail.
    "If you subscribe to voicemail service offered by your telephone service provider, New voicemail and appear on the handsets when you have new voicemail messages. Contact your telephone service provider for more information and assistance about using your voicemail service."
    I have inserted the manual below
    LINK
    HOPE IT HELPS, ALAN
    15helpful
    4answers
    How do i set up my voicemail...manual not explaining ...please list steps ....
    Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
    To call your voicemail service
    1. From the Home screen, tap Phone.
    2. Touch and hold down 1.
    If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
    To enter your voicemail number
    1. From the Home screen, tap .
    2. Find and tap Settings > Call settings > Voicemail settings.
    3. Enter your voicemail number.
    4. Tap OK.
    Hope this helps. If so, please rate the solution.
    -regards,
    M
    How to set up voicemail
    If you have an active voicemail... but have never activated it:
    The default password is 0 0 0 0 (four - zero's)
    The voicemail will talk you right through setting up voicemail, after the set up you can press 8 anytime you are in the voicemail to make changes to your account.
    Cant set voicemail up
    Call customer service something odd is happening you don't need to re-set up voicemail moving your SIM from one phone to another. If the phone is one not from your carrier it might not be programmed for your carrier's number when you press and hold 1 to dial voicemail
    Top Lands Phones Experts
    k24674
    Are you a Lands Phone Expert? Answer questions, earn points and help others
