Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator Logo
Posted on Nov 15, 2009
Door handle are loose
Door handle on fridge & freezer are loose
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1279
Points
Get a 2.5 allen wrench and tighten the bottom side of the handle
How to tighten a loose door handle for On the fridge upper half?
Gain access to inside of refrigerator door to refasten the loose handle.
How do I do fix the handle of my Matag refrigerator #M1TXEMMW803. It is loose on the bottom.
Maytag Repair - YouTube
? 2:17
https://www.youtube.com/watch?v=KcPy_PWb_Iw
Aug 27, 2013 - Uploaded by hpaiz69
Maytag Side by Side Loose Door Handle Repair. ... RefrigeratorDiagnostic & Repair - Not cooling ...
LG Refrigerator Repair (Part #AED37133117) - YouTube
? 1:01
https://www.youtube.com/watch?v=BXupc6y_wgw
Jul 9, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the handle is when it . ...Fridge Freezer Door Handle Replacement ...
How to fix a loose Refrigerator Handle - YouTube
? 0:30
https://www.youtube.com/watch?v=4IO60zkMXpw
Dec 12, 2013 - Uploaded by Charles Joyner
How to fix a loose Refrigerator Handle .... Refrigerator Repair - Door & handle, Amana , Whirlpool, Maytag ...
How to tighten loose set screws on freezer door handle on ken more fridge with bottom mount freezer, model no. 269-76353019
I think that the handle is attached either to the door edge or the face. In either case the screws are usually hidden behind a small trim panel. This needs to be removed to expose the screws. I don't know what type of screws have been used. They're usually cross heads but occasionally they require an allen key to remove them.
1helpful
Fridge freezer alarm going & turning from blue to red
Possible there is some issues with the control panel and must be taken out to be confirmed. It can also be some loose connection on the connectors or the lamp holders.
Also check the wiring to the board.
Door and handle problems. Smeg fa311x
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
Fridge freezer hotpoint fridge wont get cold!! and the freezer is not freezing
Empty the freezer & fridge, turn the unit off, leave the door open for 24 hours, to let all the ice melt off the coils, then turn it back on & make SURE the doors are closed well.... You will know that this was the problem in about 3 hours, when the freezer is back at normal temp.....
Be sure to put some towels in front of the unit, and also inside the freezer when it is off, as you may have more water (melted ice) than the drain pan can handle.....
4helpful
The door handle on my samsung RSH1NHMH freezer is loose how do I tighten it
You will see a small hole on the underside of the handle at the two points that the handle touch the fridge door,put a small straight nose screwdriver in this hole and turn 90deg which will expand the metal clip inside at the same time pull the handle away from the door and it will come off.You can then screw the handle holding clip into the fridge door and then push the handle back on.
5helpful
Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
3helpful
Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
3answers
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Top Fisher and Paykel Refrigerators Experts
Grand Canyon Tech
Grand Canyon Tech
NOEL
NOEL
john h
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
