I'm having problems with the dispenser cups emptying.
They remain full of water, or sometimes even bleach after the load runs full cycle.
OR
the bleach will run down the front of the maching as I am filling the cup, ruined a whole basket of laundry that was waiting to be loaded in the following DARK load!
AND
the softener cup is emptying underneith the cup as I fill the other cups...
WHAT'S GOING ON?
I had the same problem with my LG front load. The second repairman fixed the problem. The water lines going into the machine were clogged with sediment (probably because I have well water). This caused the cups to remain full of water because the water pressure was so low the siphons were not working as they should to empty the cups. This also caused the wash cycles to be extremely long (sometimes 2 hours) because it took so long for the water to enter the machine for the wash & rinse cycles. Since the lines have been cleaned it works fine.
I have a similar problem where when the cycle ends and I start a new load, the cups are filled with water. As soon as I open it all the way, the water emptys by leaking down the front of the washer and a little underneath. NOW, my storage drawer on the bottom is squeaking when I open it due to all the water getting in the track. How do I fix the water from not emptying out completely?
