Sounds like a heat protecting switch is getting triggered . So I would suggest placing a fan at the back of the unit to keep it cool and to test if this is the problem as I have had issues like the one you are describing and a fan stopped the constant cut outs .
I just got done putting my panasonic 50 projection back together. There is a thermal cut off relay on top of your bulb box, can normally be seen after removing the back of the tv. With the tv unplugged make sure the area around this relay is clean of dust. If the simple fix dosn't work make sure your cooling fan is coming on with the tv.
Kevin
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did. Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
