SOURCE: sanyo plc xu 40 lcd projector problem
not only reset the timer is good enough
u must use serive cable to disable the shut off function
and technically reset the system
SOURCE: Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
SOURCE: Projector problems
Hello!
After 2 years I finnaly solved the problem. There was a flaw in the
lamp´s temperature circuit. A technician disassambled my BENQ PB8253
unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
SOURCE: We have an Optima EP
if you hear a high-pitched whir, you have a ballast problem. if you don't hear it, you have a colorwheel problem.
SOURCE: Hello with Sony VPL-CS1 projector in standby mode
overheated or lamp is past it's time. you may need to change the lamp, replace the lamp timer. while you're in there, clean it out.
