Red light is blinking I have taken the batteries out cleaned terminal and batt. still the charging light still blinks I unplugged it tried it again.still red light blinks usualy the light will just stay red until ut turns green after charged and do not have instruction anywere
Try inserting battery quickly 5 or 6 times to see if it is just a connection problem, sometimes this works in cleaning the terminals.
press the helpful button.
I think the red blinking light is a fault, normally should be a green flashing light while charging.
Switch off, remove batt, then replace the bat. You should notice a red LED blink. If that does not blink, you can't do much yourself. Take it in for a proper check by authorized service tech.
Here's a guide;
What do the battery lights mean on my mouse?
Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model
Status
Single long green blink
Rechargeable
Batteries are good. This occurs when batteries are first installed or every time that the device is turned on.
Slow green blink
Rechargeable
Device is docked in the charging station and is charging properly.
Steady green
Rechargeable
Device is docked in the charging station and does not need additional charging.
Steady green
Presenter Mouse (Japanese version)
Laser pointer is on.
Red/green blink
Wireless
Device is discoverable (trying to connect to the transceiver).
Slow red blink
Non-rechargeable
Batteries are low and need to be replaced.
Slow red blink
Rechargeable
Batteries are low and need recharging.
Fast red blink
Rechargeable
Device is docked in the charging station, but there is a charging error. Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad. Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them.
Steady red
Presenter Mouse (Standard version)
batt mayb bad test for 12.6v -is it over 3yr old---must hold that charge ovanite--any points lower means its wearing--------if system chargn fine why did u swap altnator--------that lite cud mean a failn intrument cluster or computer prob---try unplugn computer cleaning thepins-then plug bac in once or mor
Hi just got one myself and after a day same problem. Replace all your remote batteries with new ones And it will charge normally with blinking red then red and green blinking. I enjoyed flying it but enough is enough. There is no replacement blades, It eats batteries. I would go with this sites micros http://www.xheli.com/rchelicopter.html
Im looking at this one, charges with usb so wont kill batt's, Metal frame and also they sell parts http://www.xheli.com/s107-miniheli-blue.html. Good luck and happy flying.
Thermostat problem; Honeywell chronotherm lll ' Low Batt. indicator Keeps blinking after Batteries replace. I chk'd batt. with elect. volt ntr. Was told to pull batt. and change ends with them , letthem stay reversed for 5-10 sec. then put them back in right order,and replace thermostat. No success!
Anyone have any answers
Make sure that you are installing a fresh/ full charge battery
Remove the battery Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt. If you do not have access to a dif. battery. Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
I had this problem and I solved it by taking Q-tips dipped in rubbing alcohol and cleaning the contact points of both battery and charger. My batteries are now charging again and no more blinking lights!
