PDF files have become the defacto document standard on the Internet. Why? Well because it is the Portable Document Format. The file you created will look just like you had prepared it, irrespective of the software used to create or read the file or whether the other person has the fonts you used. It also offers hundreds of other options that make it truly great for the power user.
However sometimes you get a
PDF file from a friend/colleague or from the Internet that is
password protected. Some require a password to open, others have the fonts, images and other content protected and others prohibit you from printing the file. You can of course contact the person concerned to get the password, but there can be plenty of situations where you would want to use a
password protected PDF file otherwise! So, here I tell you a wonderful tool
PDF Password Unlocker.
PDF Password Unlocker is the
PDF password recovery software that allows you to
remove PDF passwords and open protected PDF files. PDF Password Unlocker
recovers PDF passwords instantly and removes all the restrictions for copying, printing and other actions. It is powerful enough to
recover PDF passwords of any strength with a speed higher than most of the existing programs. It's a premium program that unlocks PDF files created by either Adobe Acrobat PDF or any other PDF applications.
Main Features:
All Adobe PDF versions are supported through the latest 9.0
Support PDF files created by other PDF applications
Recover PDF password for opening the file
Instantly remove restrictions and enables copying, printing and other actions, etc.
Powerful enough to recover passwords of high strength
Support 40-bit RC4, 128-bit RC4, 128-bit AES, 256-bit AES encryptions
Available of brute force, brute force with mask and dictionary attacks
Double in speed when compared to similar programs
Up to 4,000,000 passwords/s for single-cored CPU, and 8,000,000 passwords/s for multiple-cored CPU computers.
Able to minimize the recovering time by customizing a password character set if any part of the password is known
Able to create your own dictionary for the program to base on
Automatically save the recovery process and resume if accidentally stopped
Work on both single-cored CPU and multiple-cored CPU computers
Simple utility and easy to use
PDF Password Unlocker is the simpliest PDF password remover for encrypted Adobe Acrobat PDF documents. It is the ever easiest-to-use PDF password recovery tool to recover and remove both the "User Password" and "Owner Password" efficiently and safely, making it possible for you not only to open but to modify the PDF document. Thereafter, instead of locked out of the document, you can open it and perform all the operations as you like, such as select text and graphics, change or add annotations, copy to Clipboard, modify the content, and print the document, etc. Functions as an Adobe Acrobat PDF cracker, it is super easy to use! Just give the full path of your PDF to the program and with a mouse click to the "Start" button on the program will be OK. There is no related knowledge required, even a kid can manipulate successfully.
the problem is that the file is password protected and i dont have it.
the file is password protected and can't even be printed.so i cant still edit the pdf file.
