Bosch Classixx WFL 2066 Front Load Washer Logo
Posted on Nov 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to wash clothes in bosch classixx 5
How to wash clothes in bosch classixx ?? i dont know how to wash, it's my first time
Anonymous
Level 3:
  • Master 460 Answers
  • Posted on Nov 14, 2009
Anonymous
Master
Level 3:
Answers
460
Questions
5
Helped
138912
Points
1023
I will be very happy to assist you in this issue.
follow this web to learn more about your washer
http://www.onino.co.uk/washing_machines/bosch_classixx_wfl_2066.html
i hope this answer your question
your rating and comment its very important to me
thank you
My Bosch classixx 6 is flashing 21 what does it mean
I have tried to do 6 clock position then 7o clock and hold on spin button for 5 seconds then let go .. Turn back 12o clock .. Then turn on programme .. It's worked .. Washing some clothes then start again f21 came on after wash.. Spin won't go on .. .???
Why my bosch classixx keeps stopping every 5 minutes
The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
8helpful
I have a Bosch washing machine /classixx 6 12 Express and the key sign is on and cannot programme wash
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
1helpful
Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
8helpful
2answers
3helpful
2answers
Bosch Classixx WFL 2462 Front Load Washer
Remove plastic panel at front bottom of washer, there you will see the filter, unscrew it anti clockwise to remove and clean, replace and tighten up clockwise.
Plz rate my solution.
Thanks.
1helpful
2answers
Hi, I have Front loading BOSH Classixx 5 washing machine purchased last week. But i dont have operating instructions in English. I need operating manual of this washing machine in english. Kamalnish
simply go back to the shop it was bought in and they have to supply with the instructions in english at your request at no further charge,email bosh at there customer services they will gladly supply you free of charg.adrian
My bosch classixx 1200 express
Close the door and turn the dial to drain
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
