Hi, You can reset lamp timer of VPL-EX3 by following procedure. Connect power cord in wall socket, standby indicator will lit red. Press following keys on projector remote.. RESET, Left arrow, Right arrow, ENTER Lamp timer will reset. Hope this will help. Thanks.
when you replace old lamp with new one the lamp timer not reset automatically the counter is a software data and you reset manually with remote control
HOW :Connect the power cord to the projector. The ON/STANDBY indicator light in red
Use remote control and press the following key on the remote control in following order for less than five second each.
RESET +LEFT ARROW KEY+ RIGHT ARROW KEY+ENTER (as show in picture)
Hi, To reset lamp timer in Sony VPL-ES3, Press following keys on the remote control in following order for less than 5 seconds each, RESET, <<, >>, ENTER This will reset lamp timer.
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't
when the bulb dies, but when a bulb has lost 10% of its brightness - so
you might well be able to reset the timer and get much more use from
the bulb - the image just wont be as bright.
Once the filter is replaced, plug the projector back in and make sure the projector is in standby mode. Point the remote control at the projector and press the following buttons in order in less than 3 seconds: reset, ←, →, enter. This worked for me. Good luck.
To reset the lamp timer: 1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual). 2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER. 3) Timer should now read '0'.
