Sakar Talking Caller-ID Speaker Phone Logo
Posted on Nov 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Item#HT555ID phone Can I get a operation manual for above or print off on line?
Anonymous
Level 3:
President:
  • Master 742 Answers
  • Posted on Jun 28, 2010
Anonymous
Master
Level 3:
President:
Answers
742
Questions
0
Helped
1020385
Points
1651
Ask at manualfox.com -they have the HT555ID manual.
Where do you plug in the fax line
Julie, Page 12 of the manual, item 21 shows two jacks, one is the line socket and the other is for a phone, in case you want a phone near the copier. Item 20 is for a network cable.
Do a search for MFX-3090 PDF and you should find the manual.
Why dont they let you have a manual with your new phone anytime you have aproblem you either have to go to car phone warehouse or go on line this is not fair
Printed manuals cost a lot to produce and add a lot to shipping costs as they have to be a weighty item in umpteen different languages. Most owners never consult them anyway, so they are a waste of resources all round.
In exchange, you can usually find a complete pdf copy online or sometimes a manual is included on CD, but even those can make the phone packaging larger than necessary. An increasing number of phones have the manual stored in the phone memory..
Like you, I prefer a printed manual, but I also want my phone to be supplied at the lowest possible cost. The present alternatives for me and the vast majority of customers are seen as an acceptable compromise and many prefer them as they're better for the environment.
I have a Sakar speakerphone HT555ID, but I lost the userguide when the process of moving. Could I be sent a Userguide or manual. your response is awaited. Thank you. [email protected]
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Hello. I have a Mimaki JV33BS Plotter (1.6m print width). Suddenly as from couple of weeks ago the plotter started printing some black dots everytime there is an image or color to print. This dots are...
Sounds like a cleaning issue.
Drivers for your printer can be downloaded from here:
http://www.mimaki.co.jp/english/download/uc_index.php
Manuals available here:
http://www.mimaki.co.jp/english/download/manual/#jv33
You may want to review page 158 of the PDF of your Operation Manual with respect to Troubleshooting when Image quality is poor. This document points to a number of sections with respect to specific cleaning requirements.
2answers
Brother Mfc9840cdw (except for fax send) has been very good. During print job (2nd computer sent job during print from 1st computer), red light suddenly came on. everything stopped. No sign of a jam. No...
the machine is nearing service time.. Normally this is maintenance and resetting the print clock..
  • press both 3 and 9 buttons at the same time and hold
  • select each item 1 at a time and press ok
  • press 1 to reset it..
  • do this for each item in the list
  • repeat for each item.
3answers
Only First Phone in the system will ring on incoming calls
These manuals are available on the norstar web site.
Home phone
unplug phone line from printer, see if phone is operational, try another phone in the wall plug, if not working, go to outside box and plug phone into the test item, if not working call phone company as it wuold appear line dead/cancelled.
Language
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Problem with oki microline 395
Enter the menu,
Menu Mode
2. Power ON the printer4.gif.
5. The line shown below will print4.gif.
Step A
Step B
A line prints4.gif, showing the Group.
Scanning Problems
I need some more information are the lines horizontal or vertical? Does it print fine from the computer? Does this problem only happen when you scan an item in and then print it or copying an item then print it? Also when you get this output do you have some of the text and lines or just lines?
Top Sakar Lands Phones Experts
k24674
Are you a Sakar Lands Phone Expert? Answer questions, earn points and help others
