Baby Gear Logo
Posted on Nov 12, 2009
How to adjust car seat straps? - Eddie Bauer Baby Gear
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 24, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
463
Points
Have a 1999 evenflo toddler seat took the straps out to wash cover and have no idea how to fix them
4 Related Answers
Anonymous
  • 50 Answers
  • Posted on Jun 27, 2007
SOURCE: Maxi-Cosi how do you adjust the straps
Take a look here ,you have the manula and if you want you can get to know the FAQ. Thanks. http://www.maxi-cosi.com/maxicosi/productindex. aspx?cat=p
Anonymous
  • 133 Answers
  • Posted on Jul 31, 2007
SOURCE: Shoulder restraint adjustment
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
Anonymous
  • 5 Answers
  • Posted on Nov 20, 2007
SOURCE: strap adjustment
what brand/model of car seat is it?
smurfymom
Ariel Keeley
  • 5 Answers
  • Posted on Jun 21, 2008
SOURCE: i can not for the
there is a thing on the back that the strap goes through, press up on it while pulling from the front on the straps
How do you adjust straps on a baby car seat?
Graco SnugRide 35 : Adjusting Harness Straps - YouTube
? 6:41
https://www.youtube.com/watch?v=vl_JSaEuu0U
Jun 23, 2012 - Uploaded by Baby Car Seat Installers
This video shows how to adjust harness straps for the Graco ...Graco SnugRide 35 : Adjusting Harness Straps. Baby Car SeatInstallers.
Britax B-Safe: Adjust Car Seat Harness Straps - YouTube
? 3:12
https://www.youtube.com/watch?v=XGHnSLXRqq8
Mar 2, 2014 - Uploaded by Baby Car Seat Installers
We teach you step by step on how to move the harness strapshigher as your child grows. This video is for ...
Ihav lost car seat info and need to know how to alter strap at front of chair between babys legs...
Depending on what kind of car seat you have, you may not be able to. Most car seats have a fixed strap in between the baby's legs, while the shoulder straps are adjustable.
Jun 02, 2011 • Baby Gear
1helpful
2answers
I am having trouble adjusting shoulder straps
Funny, I was just putting this seat back together after taking it apart to wash it. It is a very difficult process, simply because you have to remember which order to loop the buckles through the stap.
First, I assume you want to switch from the lower holes for the shoulder, to the upper. (If not, then there is no adjustment needed. Unless the strap is caught in the back which will make the straps uneven when you go to tighten them. This has happened to me).
So, first you need to remove the straps. Once the seat is removed from the car, look at the back of the seat and you will see a metal bracket that is holding three straps. The bottom strap is not removable from that bracket. The top two strap are attached to the bracket with loops. Remove the straps by sliding them out (edge of the strap has to come out the hole first, then the rest will slide out very easily), Once out, from the front of the seat, pull the strap through the holes
At this point you must decide whether you simply want to adjust the seat, or wash it too. I highly suggest washing it if you haven't done so recently. If you gone this far, go all the way. But since you only asked to adjust it, and the method for removing the cover is much more complicated, we''ll move on to adjusting
Now that you have the straps pulled through, be sure that the straps are not twisted, and simply push them through the desired holes - upper or lower - and reconnect to the loops brace (remember, edge in first).
If you are having problems with the straps not being even when tightened (one side tight on shoulder, other side loose), remove the seat and look to see if the strap is caught on something.
I'm retiring my seat today after six years and two kids. I could use it up to 80lbs, but it makes it difficult to get to the third row of seats in my car. So now we have two no-back boosters.
12helpful
I have no idea how to get the stupid straps back in. Can I get some dang directions?
My daughter has a car seat just like this one, and I wash it about once a month so I hope I can explain this detailed. First, at the base there is a metal rod that will need removed. When you take this rod out the base and seat will seperate. Set base aside and turn seat upside down. Take your strap and put an end into each slot. Turn seat over and pull your straps even. Put the two black pieces for your latch on (one on each side) then put you chest pieces on and run straps thru slots on back of seat. Turn seat around and make sure the straps go OVER the silver bar in back (this allows you to adjust shoulder height) Secure to the metal piece that runs to front for tightening adjustment. Set seat back on base and replace rod. Hope this was helpful.
4helpful
Car seat adjustment for britax eclipse
Tilt seat back and slacken straps fully. Follow each shoulder strap through back of seat and down towards lower back of seat. There you will find (maybe hiding under a plastic cover) a metal bracket that retains the straps. You can slide the straps out of this, pull out and thread back through at a higher point.
The actual tension adjust ment is usually a metal clip that you push or pull which is located in the centre/ front are of the seat, or front/centre, underneath where the child's feet hang.
Strap Adjustments
Yes, Im sure you can find it in a department store or online store. Try target.com probably, they are called extension strap like this http://www.babyonthemove.co.nz/shop/Car+Seats/Carseat+Accessories/600mm+Extension+Strap.html?id=akv7atuH
1helpful
2answers
Strap adjustment
I'm trying to adjust the straps to fit my newborn when she arrives. I can see how it should be pulled through but it tends to get stuck and I can't get it all the way out. My other concern is that if I do get the strip out hoe hard is it to get back in the hold to lock into place.
12helpful
4answers
Carseat harness straps
You have to unloop the straps from the gold metal bar. This will allow the straps to be free so you can feed them thru the holes and re-feed them into the proper height hold. You will than noticed that there are loops at the very end of the straps which you can loop back onto the gold metal bar.
Sep 23, 2007 • Baby Gear
33helpful
6answers
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
2answers
Infant Rear facing car seat
ON THE BACK OF THE CAR SEAT ARE TWO LATCHES SIMPLY REMOVE ONE BY PUTING THE STRAP THROUGH THE LATCH AND ADJUSTING IT TO YOUR CHILD FIT DO THE SAME TO THE OTHER. LET ME KNOW IF I WAS ANY HELP...
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Paul Bade
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
