I have a bosch WFR 2460 washer. When it is draining, I hear the motor running and it says "Pump Blocked?". I have error code Er:15. What does this mean?
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Testimonial: "Thank you so much. There were some wood splinters and a nail stuck in there! No wonder it wasn't working!"
how to replace shock absorbor on a bosch 2460 washer
