Zanussi ZBF360 Electric Single Oven Logo
Posted on Nov 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Zanussi 360 just tripped and now keeps tripping
Zanussi 360 built in oven just tripped and now keeps tripping when attempting to start? hob still works.
Barry Coates
Level 3:
  • Zanussi Master 3,463 Answers
  • Posted on Nov 11, 2009
Barry Coates
Zanussi Master
Level 3:
Answers
3463
Questions
Helped
1405831
Points
12766
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Please rate my solution.
Thanks.
Fuse keeps tripping
tripping a circuit breaker indicates a dead short or insulation failure
not being able to move the main switch indicates that the contacts inside are burnt together
only option is to call an accredited electrician to test the circuits and rectify the fault
tell him to bring spare elements is case on e or both have burnt out
Zanussi oven zbf 360 + bulb blows repeatedly
bulbs blow from incorrect voltage in use or loose ground wires ( arcing out)
if they fail while the oven is on it is because the bulb construction glass is wrong
bulbs used in ovens need a special heated treated glass and are generally only available from the service agent
failing immediately on turning on indicates a bigger problem that the bulb so call in an electrician to test the system
1helpful
2answers
Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
1helpful
Oven tripping
Was the oven tripping the the fuse before the element was replaced,also did you take the oven out to do element because the element can be done with cooker in place it may be that you pulled out the connections block at rear of unit and it is touching body.If tripping before replacement the fault could be any where on the oven.You will have to check it through.
2answers
Zaunssi ZBF360X built in Oven Not Heating
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
1helpful
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
1helpful
My cooker keeps tripping the electricity
Disconnect the the supply to fan oven element, and try running it, if it does not trip,, then you need to replace the element.
Plz rate my solution.
Thanks.
5helpful
2answers
Oven keeps tripping the electrics
I would suspect that the fan oven element is faulty. what I think is happening , is as the element gets hotter, the insulation is breaking down and causing the trip to operate, it is quite a common problem
You will need to fit a new element.
If it is a fan assisisted oven you will find the element behind a removable cover at the rear of the oven compartment..
Thankyou.
15helpful
2answers
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Top Zanussi Ovens Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
