Pentax Optio 330GS Digital Camera Logo
Posted on Nov 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I installed driver for my pentax 330gs and its now corrupted and can not be uninstalled, how do i remove it? i have tried removing it from add & remove program, used the software installation remove and im geting uninstall.dll ???\C:\program files\pentax\pentax usb device\_uninstall.dll ???????????????????????? how do overcome this error:
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Nov 11, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2197939
Points
38521
Forget all that. If all you want to do is download your pics from your camera, use a card reader to download to a folder you create on your desktop.
Optio 330gs Windows 7 compatibility?
http://www.pentaximaging.com/support/manuals-and-literature/
You also might want to consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
That is the problem. How do you uninstall it? Because the Manual doesn`t give any information as to how it`s done.
Uninstalling depends on several things.
If you used "Add & Remove Programs" to install (some programs automaticly register with "Add & Remove Programs") you can just go to "Add & Remove Programs" and choose "Remove Program"
If that option isn't available, look in the programs folder for an uninstall program (often listed as "unwise")
If neither of these work you'll have to do a manual uninstall. This takes some advanced understanding or the operating system to do without risking messing up the operating system. You'll need to delete the program(s) manually then use the registry editor to remove the references to the program. Be sure to back up the entire system first and then the registry before beginning (one bad key stroke can corrupt the entire OS).
Note: I didn't give step-by-step instructions on the manual uninstall because if you don't already know how you shouldn't try.
Installation corrupted, how do we uninstall. Unins...
i have a corrupt flip video file,but cannot uninstall because it is not on my add/remove prog.
help
PK-635 Web Cam: my a4tech camera program was corrupted. kindly pro...
Uninstall first completely the driver from your computer. Go on Start, click control panel. On control panel double click add remove program. Scroll down to select your web cam driver. Click remove, then restart computer.
To install the latest driver for your web cam and the manual, click the files below
1. A4TECHPKDrivers.rar
2. PK635.zip
3. A4TECHPK-635TroubleShootingManual.pdf
Good luck. Please give a good rating if you successfully install your webcam.
I have uninstalled a downloaded program but it also uninstalled two of my drives in windows xp drivers, it now shows error 41
hi, i have a story to tell,,first time i got a pc for my son,, we install many games and softwares,,we didn't know that some of this games and softwares may corrupt some programs and even the windows..Today before we install any games and softwares we check the list of programs or wright on paper ,programs from "add remove programs" of our xp..If we install new game or software and became unstable or sometimes hanging,,better remove it from "add remove progams",,not uninstall the program..don't install any downladed software if you are not aware of that software,,
1helpful
Ty so much fredinot. i think u are exactly right. How do I uniinstall old driver in control panel. This was the one that had file corruption with static on my webcam- jack thx again
To uninstall the driver, click the "Add or Remove" program (for Win XP) or "Programs and Feature" (for Win Vista).
The window will be populated with the list of drivers that are currently installed in your computer. Find the driver that you would like to delete or uninstall, click it once and then click the "Remove" or "Uninstall" button. You will see the progress of removing the driver.
Good luck and have a good evening!
2helpful
2answers
SCSI/RAID Host Controller/Driver cannot be found
Windows cannot find the correct drivers for this device. So, let's research a little bit.
Are you using SATA or RAID on the computer? If not, there is nothing that needs fixing.
If you are, then reinstall the RAID software from your motherboard installation disk, which should repair this issue.
If you do not have the driver installation disk from your motherboard, for whatever reason, go to their website. Almost every motherboard manufacturer provides easy access to drivers.
good luck
tony
Have wrongly installed the driver and i want to uninstall the driver and re install it in my pc. when i try to uninstall the driver the following message appears. c:\windows\PIXTRAN\DR2080C.isu is eit
Are you uninstalling from Device Manager or add/Remove programs in Control Panel?
Try both methods ,disconnect the device first.
If it doesn't work then try to remove it in Safe Mode .
Add/Remove Programs
Try this: click start>right click my computer>properties>hardware tab>device manager>network adapters>choose the device you want to get rid and click on un-install. Go back to add/remove and see its still there. If not great, if so you may have to go around your pc and manually delete every thing that's associated with this device. One other thing you may try is to reinstall the original software and then try to remove it through add/remove by reinstalling you set the software back at its defaults and restore missing of corrupt files. This should restore the un-install file you need to completely un-install the device your try to get rid of.
anaanymous
Pentax Option 330GS problem turning on
Sounds like the images are corrupted on the card. If you have another card then try starting the camera with it. To get the card working again, you will need to format it in a card reader with FAT16 format, or try in another camera. If you want the images, you will have to obtain repair software to try to retrieve the images.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
