Question about Mathsoft StudyWorks! Middle School Deluxe Math 5.0 (11543) for PC
Choose four digits, all different, and place them in a 2x2 grid so that the numbers across and down total 200. How do I do it?
    New Friend:
    Problem Solver:
  • 5 Answers
A two by two grid forms four quadrants. In the upper left quadrant, place a 4. In the upper right quadrant place a 2. In the lower left quadrant, place an eight. In the lower right quadrant place a 5. Horizontally, the numbers 42 and 85 are formed. Vertically, you form the numbers 48 and 25. The sum total of these numbers is 200. 42 + 85 + 48 + 25 = 200.
Posted on Feb 02, 2010
6ya staff
SOURCE:
How many different number combinations are there using the numbers 1 1 0 8
I assume you mean different decimal numbers, using those four digits, right? If so, the answer can be reached two ways.
One way is to actually build up the model by changing one digit at a time, then moving a decimal place. Thus: 1108, 1101, 1100 then 1118, 1111, 1110 then 1188, 1181, 1180 and so on. You will count 81 combinations.
Since those three different digits can be placed in four decimal places, the answer in another way is: 3*3*3*3=81.
Sep 27, 2014 | Office Equipment & Supplies
My TI-84 calculater is calculating the problems in a very weird way. For instance if i type in 2x2 it will give me the answer 4e0. Is there a way to fix it?
That is the right result: 2x2 is 4 times 10 to the 0th power. But if you don't want your answer in scientific notation, press MODE, highlight NORMAL on the first line, press ENTER, then press 2ND [QUIT]. (You can also select the number of digits on the second line, or FLOAT and let the calculator choose.)
Oct 07, 2010 | Texas Instruments TI-84 Plus Calculator
How do you clean HP print heads
  1. Cleaning a printer's printheads is an easy process. Here's how it works (in Windows). Click the Start button (or in Vista the Windows icon) at the lower left corner of your screen.
  2. Click on Control Panel. Next, choose Printers and Other Hardware, and then View Installed Printers or Fax Printers.
  3. When the Printer page opens, right click on your printer's name, and choose Printing Preferences.
  4. For the Pixma MP530, the Printing Preferences has five tabs across the top; choose Maintenance. Again, most printers should have a very similar set of options.
  5. The first button is for cleaning the printheads. You'll have to choose which printheads you want to clean (the Pixma inkjet has five cartridges). The best bet is to choose All Colors.
  6. Make sure the printer is turned on and that there's some paper loaded, then click on Execute.
  7. The printer will print out a pattern with a grid along the top and six bars of different colors. Two images will display on your monitor that you can compare to the printed image. In one, the grid and colors are sharp and clear; in the other, some of the grid boxes are missing and the colors are striped.
  8. If the printout matches the sharp, clear image, simply click Exit and you're done.
  9. If the printout has missing grid boxes or stripes, then click Cleaning. Once that's done, you'll repeat the whole process so you can ensure the cleaning was completely successful. It may take two cleanings if your printheads are really clogged.
  10. If, after two cleanings, you're still getting a poor result, there's a Deep Cleaning option on the Maintenance tab that should do the job.
Oct 03, 2010 | Computers & Internet
Hi I have commercial hvac goodman unit and trying to change my filter, but i have no idea where the filter is located. the model number is GPG13480903AB
On this package unit, there are no places for filters inside the unit itself unless a technician rigged something up to accept one, but not a common thing at all. These units will use filter return grills inside the building. They are usually 2x2 grills on a dropped ceiling grid or could have a filter grill located right off the return plenum from the unit. Either way, it should be inside somewhere and easy to access. Hope this steers you in the right direction and good luck!
Aug 24, 2010 | Goodman Heating & Cooling
Need instructions for the game count across by Cadaco
Count Across™ Instructions
OBJECT OF GAME
The first player to place four chips in a row, either vertically, horizontally or diagonally wins the game.
Contents
1 Wooden Tray with Content Holder 1 Clear Plastic Slide with holes
1 Two-sided Number Board
25 Purple chips 25 Green chips 1 pair of dice
Set-Up
Each player selects a set of chips (purple or green). Decide which side of the number board to play, Addition Only (blue side) or Addition & Multiplication (red side). Line up the Number Board underneath the Clear Plastic Slide so that the numbers line up through the holes. The raised tab on the Clear Plastic Slide should be face up. Slide the Number Board and Clear Plastic Slide into the Wooden Tray together. The Number Board should rest underneath the Clear Plastic Slide. Each player rolls the dice once to determine who plays first. The player with the highest roll goes first (Player 1).
Addition Only Play
The Player 1 rolls the dice and adds the two numbers on the dice. Places one of your chips on the Number Board over an empty number space that matches the total of the dice.
Example: A play a rolls a 5 and a 3. 5 + 3 = 8
Player 1 finds an empty number 8 space on the Number Board and places a chip into that slot. Player 1 may choose any open 8 on the number board, but may only place one chip on the board per turn.
Player 2 then rolls the dice and places a chip in a space on the number board that matches the total of the dice. Play continues back and forth until one player gets 4 chips in a row, horizontally, vertically or diagonally. A player can remove an opponent's chip from the board in the following instances:
• If a player rolls doubles, they may remove an opponent's chip if it occupies a space that matches the total of the dice. Example: A player rolls a 4 and a 4. 4 + 4 = 8 and if an opponent has a chip in an 8 space on the Number Board, the player may remove the opponent's chip and replace it with his or her own chip.
• If a player rolls the dice and there are no empty spaces matching the total of the dice, the player may remove an opponent's chip that occupies a number space that matches the roll (if only the player's chips occupy those spaces). Then the play ends.
Addition & Multiplication Play
The rules are identical to the Addition Only play, except on each roll players may choose to either Add or MUltiply the numbers rolled. Example: A player rolls a 5 and a 3. The player may do one of the following:
• Add the dice together (5 + 3 = 8) and place a chip over an empty 8 space on the number board
• Multiply the dice (5 x 3 = 15) and place a chip over an empty 15 space on the number board
Warning! Do not throw out the Content Holder. It serves as a platform for the number board as well as storage for the chips and dice.
Jun 19, 2010 | Cadaco Count Across Game
How to set my bushnell scope 3-9x40 for 200 yards
The Bushnell 3-9X40 has been around for quite some time in several forms, but it is pretty standard to set it like any other scope.
With the gun resting solidly on sand bags or something like a Lead Sled, shoot at a target with a 1" grid on it. Those targets are a free download at http://targetz.com/, but you have to browse to find them. Targets No: 10049 or 10058 are both usable, if you can see a 1" aiming point with a 9 power scope at 200 yards.
With a known point of impact (POI) at 200 yards, you can move the POI to where you want it (inside the caps at the center of the scope, there are adjusting screws or slots). The norm is 1/4" per click (the adjuster can usually be felt to click) at 100 yards or four 1/4" clicks for an inch. At 200 yards, the adjustment will be twice what it is at 100 yards or 1/2" per click.
Make your adjustments, using the grid on the target to tell you how many inches it needs to move, and shoot the target again to confirm the adjustment is correct. It's pretty standard to shoot at least a three shot group to ensure the bullets are reasonably close to each other.
Another method is to set the POI at a certain number of inches high at 100 yards and assume it's right at 200 yards. If the mid range trajectory, for your cartridge, at 200 yards is X inches high at 100 yards, you can set your POI to that X inches high and be pretty close at 200 yards.
Nov 07, 2009 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
Estimate the total cost by rounding the total cost of each car an
195 reps --> 200; $21710 --> $21700; 200 * 21700 = $4,340,000
Sep 04, 2009 | Casio MS-80TE Calculator
Copy formulas
It should work if you just copy and paste it. Or select the range of your working area and right click in destination cell and choose paste special. When new window pop up, just choose Formula.
It should work usually, but by any chance you've encountered the problem regarding this. Just let me know...i'll try to help you...
P.S.: If this information was helpful, please rate this solution.
Mar 23, 2009 | Microsoft Office Excel 2003 for PC
Filter grid alignment
First, I don't understand why I could not submit my question when the filter model I have was not listed in the drop-down of models. As I wrote in my question, I had to choose the wrong filter, JUST to get the question submitted. NOTE: This instruction is for Hayward DE filters. Mine is a DE 6000, but I believe the instructions apply to all sizes.
I did solve my question by:
  1. Place the grid manifold upside down on a flat surface. (Holes up, remove the air escape tube first.)
  2. Start with the SMALL filter grid(1 of 8) and insert it in the location hole to the left of the stand pipe inlet. (The LARGE hole in the manifold.)
  3. Continue inserting the remaining 7 filter grids counterclockwise into the location holes, with the tight curl of the grid going toward the center.
  4. The base plate (circular swirl piece) is now worked onto the filter grids, BEING SURE THE "CUT-OUT" FOR THE STANDPIPE ALIGNS WITH LARGE MANIFOLD HOLE, where the standpipe will be.
  5. I found working from the center outward, and giggling the plate as I progressed, the filter grid ends worked their way into place. You'll know it's in place when the plate feels solid and is parallel with the manifold. The filter ends will be in the correct notches and the grids will be symmetrical.
  6. Drop the stainless center rod (with washer and nut in place) through the base plate and into the hole in the center of the manifold.
  7. Holding the assembly together, by pressing the base plate and manifold together (with one finger on the rod), turn filter grid assembly over.
  8. Place washer, and tighten nut, on top of rod. Replace air escape tube and tighten clamp.
  9. Lightly lube the standpipe with Vaseline and place the filter grid assembly into the bottom filter housing.
  10. Lightly coat large "O" ring with Vaseline and place onto top lip of bottom filter housing.
  11. Place filter housing top on top of the filter housing bottom, being sure to create an equal size gap between the 2 pieces.
  12. Place the clamp ring around the seam and tighten both screws until the springs are completely compressed. (There will be a slight gap between the clamp ring halves.)
  13. Fire up the pump, add fresh DE through the skimmer return line to the filter, and enjoy your pool.
Mar 19, 2009 | Hayward Easy Clear 40 Sq Ft Cartridge Pool...
Mathsoft StudyWorks! Middle School Deluxe Math 5.0 (11543) for PC Logo
159 people viewed this question
Top Mathsoft Computers & Internet Experts
k24674
Bapco
rhodesworks
Are you a Mathsoft Computer and Internet Expert? Answer questions, earn points and help others
