Casio Z70. When switching on the camera, lens comes out but makes a faint clicking noise from the lens drive mechanism inside and the camera does not come on. I have tried a dismantle and clean up inside even to the point of removing the zoon lens assembly but still the same problem. Any idea what I should try next. Thanks.
SOURCE: casio camera lens stuck
I fix digital cameras call 214-650-6531 or email me at [email protected]
SOURCE: Where can I buy replacement parts for Casio EXILIM ZOOM EX-Z60
I have those parts available at [email protected]. Thanks
ebay or I have one for 60.00
www.digitalcamrepair.com
i droped my camra and now the lense is like stuck where can i go to get it fixed
SOURCE: Casio exlim EX- Z29 lens error upon power on
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track -- either of these problems will require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be too weak/worn to properly power the camera, or the camera may require professional repair.
The lens mechanism could be jammed and cause a failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre., being an expensive camera
get estimate before you decide. It will be good to have it checked at the Casio service as you do not have to run around for spares.
