sorry to say but you have your keypads gone splushed out need to repair. bt sumtyms it works itself bt u need to repar ur keys sorry to say but you have your keypads gone splushed out need to repair. bt sumtyms it works itself bt u need to repar ur keys
You can't post conmments that contain an email address.
Has this always happened?
Does it happen every single time? are you in cellular coverage, or does it happen only when you are in certain areas?
Have you got your call diverts set up correctly?
I am not familiar with this phone but some phones you have to select an option to enable DTMF. When you are in a voicemail call, try selecting options or menu and see if there is an option to enable DTMF.
Dual Tone Multi Frequency is the sound the keys make when you select them and this is what is not being sent by your phone and your voicemail needs these sounds to know what key you are pressing.
my w910i keypad not working at all.call, end call,menu,cancel, and shortcut key not working (but num'ric key pad is working properly). can any one guide me to fix it...
My recently purchased LG600G (Target $30) immediately started receiving unwanted calls that forced me to figure out voicemail. Well, when I say "immediate", I mean once I struggled through the activation process! Turns out I wasn't pressing, and holding, one of the keys. The first of many firmware issues, read on.
Ironically, the phone is not by default setup to use the keypad for entering responses and I needed to enable DTMF tones. 9 Settings, 5 Call, 7 Send DTMF Tones. (btw, p.62 of the manual lists menu options 9.5.8 which is wrong). Select 1 then set.
I was then able to check my voicemail but my phone still doesn't actually let me hear the DTMF tones. I also have to hold the keys down longer than other phones; it doesn't like flying fingers.
Usually I check voicemail using a land line (or my wife's free work cell!). My local number is not my area code. For AT&T the requested mailbox is the cell number, followed by the 4-digit passcode.
View or edit the Mailbox Retrieval number, then select OK. Note: If the Voice Mail Retrieval number is unknown, contact Customer Care for the users local number or to have programming sent to the device.
If sounds like DTMF is turned off on your phone. If it is then it is not sending the correct tone over the air which is why nothing happens.
Go into setting, then to initial setup and key down toward the bottom and you should see DTMF if it is off change it to short or long and that should correct you problem.
