Question about LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T...
The upper compartment lights will not turn of when you close the doors.
    New Friend:
  • 47 Answers
This means your door switch is sticking...most likely needs replacing..
Posted on Nov 11, 2009
6ya staff
SOURCE:
Battery Keeps dying, Car thinks doors are still open when closed .
Please check all door close sensors for each door.
Apr 15, 2013 | 2005 Lexus ES330
Refrigerator not cooling FRS22WNC
the damper vent door between the freezer and refrigerator isn't opening to let cold air into the refrigerator compartment from the freezer side,its in the upper left corner in the refrigerator behind a grille,if its closed you wont feel cold air flowing in from the freezer sometimes you can shine a light in this area and look in the other compartment and if no light then the doors shut and this is why its not cooling the refrigerator
Sep 29, 2012 | Frigidaire FRS23H7C Side by Side...
I replaced the light switch on the subzero 550 and now the frig isn't staying cold. When door is open and I press the switch light goes off so light switch is working.
On sub Zero's this has been a common problem. Pressing with your finger to test isn't good enough. You have to test the switch function, by slowly closing the door to see if the DOOR turns off the lights.
There are so many lights in the food compartment producing so much heat that if the lights are on with the door closed, it will not cool.
When I run into this problem, which is common, I take a thin plastic shim
and tape it on the part of the door that hits the switch. 2" x 3" shim will
work well. If that solves the problem, I put a few drops of crazy glue on the shim and remove the tape a day later.
If the switch has 4 wires to it, the second 2 wires run the fan in the fresh food compartment. You can test that by pressing the switch and listening to see if you can hear the fan in the fresh food compartment start up.
Oct 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
Refrigerator light stays on even when door is closed.
Turn off the Low Ambient Switch on the upper panel of the Refrigerator door. That will turn it off.
May 06, 2009 | Dometic NDR 1292 Refrigerator
2008 Pontiac G6 Convertible retractable top won't work
2007 Pontiac G6 retractable top engine swithed off while raising, top continued to close in compartment right side upper forward pad looking thing popped and the compartment would not close, however the top will raise and go back in place, cannot leave top in compartment since the trunk lid will not close over the stored top..........
Apr 25, 2009 | 2008 Pontiac G6 Sedan
Dometic RV refrig light will not go out
Open up the door to the freezer, you will see two black switches upper right just above where the door would be when closed. Flip the first switch, then push the switch on the light in the fridge compartment and the light should go out. Thinking that switch is there to help reduce moisture inside fridge, just got pushed by mistake and light remains on. Hope this helps.
Ron1247
Apr 08, 2009 | Dometic NDR 1062 Refrigerator
Light stays on with doors closed
press the swith by hand,work,check the door if it touch the swith.otherwise,ckech the swith
Mar 30, 2009 | LG LRFD25850 French Door Refrigerator
Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Nov 06, 2008 | Ovens
Re: Lg Lrtpc1831t
Shirlee, you might not have the refer leveled right. The doors should close by themselves when released. Have someone bring the front levelers down so it is pitched back a little. This should eliminate the freezer door staying open. This is caused by the rush of air from the lower compartment to the upper compartment during closing.
Nov 03, 2006 | LG LRTN19314 Titanium Top Freezer...
Fresh food compartment not cold, light is lit when door closed
Engwah, is this the correct model number or does it start with PSS. The light should do just the opposite, off when the door is closed and on when the door is open. This could be part of the non cool problem. If this model has the mother board wich controls the refrigerator it is very possible that the defective fan motor has damaged the motherboard. This is very common in GE refrigerators. The technician will have to run some tests on the board to eliminate it...Catriver..post back.
Oct 28, 2006 | GE Profile PSW26P Stainless Steel Side by...
LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Logo
144 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
deecee73
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
