Thomson 24WK25U 24" TV Logo
Posted on Jan 07, 2008
Thomson 28WR25UG Hello,i turn on my TV and it's on stand by(red light)and when i press a channel up or down i can hear i high pitched buzz but the TV seems to remain in stand by.Is there anything i can do before i take i to a TV repair shop. Thanks Andy
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Jul 04, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
4909
Points
35
Your tv is gone to 'standby' mode, it definately needs to be looked at by a tech...hope the repair is not too dear
Was working fine last night ,went to turn it on and you can hear a buzzing by where you plug in your jacks a bee,or high pitch sound.tv has no picture or sound.only sound you hear is this buzzing
Sounds like your power supply is causing the problem. Unplug the TV wait 10 minutes, look in the back for a red button (circuit breaker) push it in. If this does not work you have a low voltage power supply fault.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/reuben_09f18ea112b9b936
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Red light is flashing and TV will not turn on Dynex DX-22L150A11. Also i hear a high pitched buzz when TV is plugged in.
I would recommend taking it, along with your receipt, back to the place of purchase to pursue warranty options.
Lost remote control, have two different universal remotes but cannot get either to operate the tv, it is a thomson 28wr25ug black diva, is there a code that i need
Hello
Buy one PHILIPS UNIVERSAL REMOTE CONTROL - MODEL NUMBER SRU 5130/86. Thomson TV is listed in its codes. The code is [2972]. You will get its manual also with it, which contains nearly 100 pages, and all adjustments are well explained it it. OK.
1helpful
2answers
Thomson 27 LCDB 03B
when i turn on my tv the light turns orange green for a few seconds.
1helpful
Sony KF-50WE610 flashing power/standbylight
Its small board with few connectors and easy to replace.
You can buy required part from Part Store. You may see image of ballast supply there.
1helpful
High pitched noise
I am about to post a in depth guide about how to fix this problem. It's because a capacitor inside the TV has blown which causes the buzzing high pitched noise. It's really easy to fix however and only costs about £1 / $2 to sort out.
You can read a similar guide here http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen but I will shortly be uploading a guide on the buzzing problem!
12helpful
2answers
Polaroid TLU 03711C - HD LCD flatscreen TV 37
I wrote a guide on how to fix this problem. It's really easy to do and only costs £1 (about $1!). You can view, download and print the guide here - http://www.scribd.com/doc/13515584/Polaroid-TLU03711C-Replace-Capacitors-Guide
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
