Worked perfect up untill now. Had a water supply valve leak and turned the water off to repair. Wife started the machine without the water turned back on (if this is any help). Did the reset that is described in the operator's manual 2 or 3 times. Still turning..... Help!!!
When the knob keeps turning, it is giving you a code by the blinking red light. count the blinks. i have a manual to explain what the codes mean and how to test the parts
Are you still active on here? my 6200 blinks 13 times when rotating and I can't find the codes.Are you still active on here? my 6200 blinks 13 times when rotating and I can't find the codes.
You can't post conmments that contain an email address.
H:H 80 on a Miele microwave indicates that the microwave's Keep Warm feature is in use. To end the cycle, open the microwave door or operate a selector or sensor (press a button (not the time display) or turn the selector knob). The keep warm setting runs the microwave for 15 minutes at 80W power starting 2 minutes after any program that used more the 450W of power. You can turn off the Keep Warm feature completely in the microwave settings. To change the setting, touch the menu button (arrow and three horizontal lines). Press OK and turn the selector knob until you see P9. Press OK and then turn the selector knob to change the setting. Press OK to save.
Electrolux Diagnostic Mode
* Press the Cancel button to enter standby mode and enable diagnostic entry.
* Within 10 seconds after pressing Cancel , press any button to wake up the control.
* Within 5 seconds of wake up, turn the selector knob to the far left cycle and press and hold Cancel and far left
button under the display simultaneously for 3 seconds to enter the diagnostic mode.
To save time at wake up, the Welcome screen can be bypassed by turning the selector knob.
1. Upon entering diagnostic mode, all lights should flash for 1¼"x2" display models and all lights on for the 1¼" x
4 3/4" display models.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water
should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water
should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and
cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The prewash solenoid will activate and cold water should
enter through the prewash compartment.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door
can be opened. When the door is opened, the drum light should turn on.
7. Turn the program knob (6) clicks from the start position. The door lock will activate and the washer will fill then
tumble. Once tumbling has started, the boost heater will turn on.
8. Turn the program knob (7) clicks from the start position. The drain pump will activate draining out any water in the
tub and the washer will operate in high spin.
9. Turn the program knob (8) clicks from the start position. This is a free position. 10. Turn the program knob (9) clicks from the start position. The control will signal the last 5 error codes with E00 being no error.
11. Turn the program knob (10) clicks from the start position. Latest software version will be shown.
12. If applicable, turn the program knob (11) clicks from the start position. This is a free position
Exiting Diagnostic ModeA) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord or
Turn the program knob clockwise back to the start position. Press the Cancel and far left button under the display
Test the dripping water with your hand to make sure that it is the hot water side that is leaking. Lay a rag over the sink drain to keep parts from falling down it. Locate the hot and cold shutoff valves under the sink and turn the knobs clockwise by hand until they close. If the knobs remain stiff, use a pair of pliers to gently turn them until the knob begins to move, then finish turning by hand.
2 Pry the decorative cap off the faucet top with a small thin, flat-head screwdriver. Remove the cap that has the "H" letter on it. Depending upon the handle screw configuration, use a flat-head or Phillips-head screwdriver to remove the handle screw. Gently pry up on the handle from all angles and pull it up and off the splines of the stem.
3 Use a crescent wrench to turn the hot water stem nut counterclockwise until it comes completely off the stem shaft. Wiggle the stem with your fingers and pull it out of the faucet. If the washer on the bottom of the stem is deformed, it indicates the source of the leak. However, remove the old seat from the faucet base with an Allen wrench or a seat removal tool.
4 Wipe out the inside of the seat housing with a rag. Replace the seat with the new one included in the repair package, using an Allen wrench or seat removal tool.
5 Place the new hot water stem shaft into the valve seat, and start the stem nut in by hand, turning it clockwise. Finish tightening the stem nut with the crescent wrench, but only to a moderate firmness -- do not over-tighten it. Place the handle back over the stem shaft and tap it down until it seats firmly. Replace the handle screw and tighten it with a screwdriver.
6 Turn the hot and cold water supply knobs counterclockwise until they are fully open. Turn the hot water faucet knob to the "On" position and check for leaks.
The diagnostic test is used to check individual component function only.
TO START THE TEST:
• Turn the Program Knob to the start position,
Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Options and
Start/Pause buttons until LEDs start sequentially
chasing, then release buttons.
1. All the LEDs will sequentially light. Pressing a
button below a light cluster will light all the LEDs in
that cluster at one time to confirm functionality.
and hot water should enter through the detergent
compartment.
cold water should enter through the bleach
compartment.
will activate and cold water should enter through the
the loading door can be opened.When the door is
position. The washer will fill and tumble. Once
tumbling has started, the Boost Heater (if so
equipped) will turn on.
position. The drain pump & door lock solenoid will
activate and the washer will operate in high spin.
position. The control will signal the last error code.
There are two options for exiting theDiagnosticTestmode
and returning the washer to normal operation:
a) Unplug the power cord, wait 5-8 seconds, then
reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after
the start position. Press Options and Start/Pause
buttons together for a few seconds until wash cycle
LEDs appear.
This is your water tank drain or boiler ****. If it's plastic, it cannot be repaired so replacement is necessary. Of course you will need to drain the tank* first before replacing the valve.
* First turn off the circuit breaker for the water heater. Turn off the cold water supply to the tank. Open all of the hot water valves at each faucet in the house for proper drainage. Connect a garden hose to the tank drain with the other end emptying into into your basement drain or to outside of the house. Open the tank drain valve slowly and allow it to drain completely.
Once it has drained, use a pair of channel-lock pliers (aka water pump pliers or arc joint pliers) to turn the base of the valve counter-clockwise and remove it. Take this valve to a plumbing, hardware of home improvement store and ask for a replacement. I recommend a brass replacement valve but a PVC one is acceptable. Pick up a roll of 1/2" teflon pipe tape too.
Wrap the pipe thread on the new valve with 2 or 3 wraps of the teflon tape. Start the valve into the drain hole by hand, then tighten with the pliers until snug and valve oulet pointing down. Make sure the valve is closed. Turn on the cold water supply valves then turn off the faucets in the house once they are purged of air. Allow the tank to pressurize and check for leaks. If good, turn on the circuit breaker and you are good to go.
As long as the heater is still working good and not leaking I would just replace the Temperature and pressure relief valve. To do this turn control knob on gas valve from on to pilot. This will maintain pilot so you won't have to relight later while keeping the burner from firing while you are replaceing t&p valve. Turn off water supply on cold water supply to water heater.If this valve won't work or you don't have one shut off supply to house. Do not attempt to remove t&p valve until you are sure water is off. Open hot water on faucet close to heater and drain a few gallons from water heater drain valve. Purchase new t&p valve at hardware store. They are pretty standard 3/4 inch male pipe thread, 150 p.s.i. rated. Use teflon tape to seal pipe threads ,4-5 wraps at least or pipe joint compound to seal threads You will need a pipe wrench to remove old valve. Turn it counterclockwise to lossen then remove. Have new valve ready to go to minimize water loss. Be carefule as water will still be hot. Install new valve and tighten securly. Turn water back on and check for leaks. Also shut off faucet you opened. Once you are satisfied there are no leaks turn gas valve to on and bleed air from several places. I hope this helps you. Thanks.
turn off water disconnect hoses those inlets are operated by cylnoids they either have trash causeing the valve not to close all the way or need to be replaced turn your selector knob and listen for the valves to click if they do and you see no trash stoping the valves they need replaceing you can call an appliance repair shop and order the parts when replaceing turn power off !!!! not to hard to replace
where the hoses go into the machines you will notice those valves are controled by solnoid switch thats what starts and stops water flow as you turn selector knob you should hear them click if that turn off water supply remove hoses from back of machine check if filter screen is in place and that there is no trash keeping valve open p.s switch from hot and cold to see which one needs to be replaced or repaired
You have to buy descaling tablets from miele. You turn the knob to program mode and keep pushing the enter button until you get to descaling. You put two descaling tablets into your water reservoir and replace into unit. Put containers under the steam valve and the hot water wand. Press enter. Turn steam valve al the way on. Keep an eye on the containers. The process takes about 30 to 40 minutes. The message will appear 'Descaling finished." Turn steam selector to O and press enter. Display will read "rinse machine, fill watertank. Fill tank and return to machine. Place empty containers beneath hot water dispenser and steam nozzle again and turn steam selector fully on. Allow water to run through system completely. When process is finished, display will read "Rinsing Finished." Turn steam selector to O and press enter Program selector is on Program Mode and display will read Descaling, Timrt, unit is no descaled and ready to use. Turn program selector to on.
My knob turns 6 times then stops explain
