Water doesn't flow out of the water line going into my humidifier. The water line has water in it, but no water comes through the valve. How do I test to see if the valve is broken or not? I've tried setting the dial to Manual, but I still don't hear the valve move and the humidifier is bone dry.
humidifiers have a drain and if there is water going in it will be coming out the drain. check drain to see if it is clear, check hoses going into top of humidifier for cracks, check filter in humidifier.
Doesn't the float valve on the water sump control the level of water in the sump?
Do you have water to the valve? (Like loose the nut on the tubing-- does water come squirting out?)
If not, you can't get humidity into your system, without water in that sump or pan! The mat can be turning-- but if it is not SOAKING WET!-- you get no humidity in the house!.
Could the main shut off valve be plugged?--
Bottom line is-- the Humidifier needs a steady supply of water-- It will go thru gallons of water every day, this time of the year!
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Your
Aprilaire Humidifier is designed to operate in conjunction with your furnace
blower motor. Most installers wire a humidifier to operate when the furnace is
calling for heat. To determine if your Aprilaire Humidifier is maintaining
proper humidity, turn up the heat temperature 5 degrees above the current room
temperature on your thermostat and set your humidifier control to call for
humidity. The humidifier control is located on the cold air return duct.To set your humidifier control to call for
humidity, turn the control dial to the off position and slowly rotate the dial
until you hear a “click” on the control.You should also hear a click at the solenoid valve located on your
Aprilaire unit.The humidifier control
will have a click point at the current relative humidity level in your home. If
the current relative humidity is 45% or the outdoor temperature is above 60F,
the control will only operate the humidifier in the test mode.
Normal
0
false
false
false
font-size:10.0pt;
No click at the solenoid valve indicates
an electrical problem.Contact your
heating and air conditioning dealer to further check the electrical
components of your Aprilaire Humidifier.
The click sound at the solenoid valve
indicates there is electricity to the solenoid valve.By turning the dial of your humidifier
control to a setting above the “click point” you should see water coming
out of the drain line within a few minutes which would indicate your
humidifier is working.
If the solenoid valve makes a click
sound and there is no water draining from the unit, this would indicate
the flow of water is being obstructed.
1.To
determine if water flow is being obstructed, turn the dial of your humidifier
control to the off position.The first
location you would want to check for an obstruction would be at the saddle
valve located on the water line supplying water to the humidifier. When
checking the saddle valve, you want to make sure it is completely open.This can be done by turning the valve all the
way to the left.If anything is clogged,
it can be dislodged by turning the saddle valve all the way to the right and
back to the left.Once this is done,
turn the humidifier control dial above the click point and you should see water
coming out the drain line. If water is still not
coming out of the drain, check the orifice and in-line strainer to make sure
they are not clogged.The orifice is
located in the tube on the discharge side of the solenoid valve and the in-line
strainer is located on the inlet side of the solenoid valve. You may clear the orifice by inserting a
needle through the small opening.Clean
the strainer by running it under warm water to dislodge deposits or replace.After clearing and re-installing the orifice
and strainer (be sure to double wrench all water connections), turn the humidifier
control dial above the click point and you should see water coming out the
drain line.
I have a HE220, HE 260 humidifier..by pass, flow thru. There is no water flow between the hot water tank and the humidifer. The water valve is on. Is there an inexpensive part I can replace myself first before calling a plumbing contractor?
If you used the plastic tubing to the humidifier(I recomend copper) there should have been a little brass tube with a flare on it. This goes in the plastic tubing to grip the the sleeve better. See if this helps
Valves do go bad, but I had the same issue and it was the inlet orifice that was plugged. To fix: Turn off the water supply. Disconnect the water inlet line to the solenoid. The water inlet line connect to ~ 1" long piece that goes into the solenoid. Unscrew the water inlet piece and remove it from the solenoid. Check it for water flow - water should slowly drip out the small orifice at the soleniod side. There is a pin-hole sized orifice on the solenoid side and it doesn't take much to plug it. There is also a narrow cone-shaped filter inside the inlet piece. You can use tweezers to remove the filter and & use a safety pin or sewing needle to clear the orifice. Check the filter, clean it if necessary, and reinstall the filter. Now check for water flow thru the part before reinstalling. Reconnect the water inlet line and turn on the water supply. Turn your humidistat to trigger the humidifier. You should see water flowing through the drain tube.
without using a meter? OK take the water line loose from the humidifier that connects to the solnoid. Turn the humidifier on or raise the humidity and water should flow. Keep in mind that if wired correctly the humidifier will only work when your furnace is running although some can be wired to bring on your furnace. You should hear or feel the click if no water comes out you may have no water flow as these valves are pretty durable and seldom fail
With the Honeywell he220, you will use alot of water, trying to turn down the water will only reduce your amount of humidity in the home, you may be able to adjust it a little but you need to take the cover off and reduce the water flow a little at a time watching the water as it flows across the pad, you just have to make sure the humidifier pad is getting plenty of water across it, to little and you lose your humidification, hope that was helpful to ya, thanks for your question, mr.grzz
If the unit was installed with a saddle valve, which is most often the case, you could try turning down the water pressure by tightening the valve a bit. Just follow the copper water line from the humidifier back to the main water line and look for a little valve that you can turn. Try to tighten this enough so that you still have water flowing, but at the proper volume so that it doesn't overflow and splash all over.
Sounds like the air flow is too great and it is blowing the water in the bottom of the tray around before it gets a chance to drain. Try placing your summer, winter damper at half closed to slow the airflow down a little.
