Toshiba REGZA 47HL167 TV Logo
Posted on Nov 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im wanting mount my 37 in toshiba regza but i can figure out how to take off the bottom brace that supports the tv as it stands. i have taken off all the screws but the brace or base still wont come off.
Anonymous
Level 2:
  • Expert 73 Answers
  • Posted on Nov 10, 2009
Anonymous
Expert
Level 2:
Answers
73
Questions
Helped
30500
Points
219
Carefull turn the tv on it's back and remove the 2 black screws in the bottom of the stand in addition to the screws on the back that I assume you already removed.
What size bolts attach tv to stand for Toshiba 37"
You will use the bolts that you take out to remove the base from the tv.
How do i remove the table stand from my 37" toshiba regaza tv?
there should be 4 screws in the back of t.v unscrew them and it will lift off.
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the five screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Five screws
Toshiba Regza lost swivel stand bolts
if your GF wants you to separate the three in one coffe what well you do?
I have a 52in Toshiba flat screen that I want to take the base of of so that I can mount it on the wall. The model number is 42XV540U.....I have removed all the screws from the bottom of the base of the...
Check carefully with a flashlight to see if you removed all the screws completely. The stand should pull out quite easily as long as all the screw are out on the back bottom center of the TV.
Cant get my stand of my tv to mount it on the wall can you help?
If you turn the set over you will see a set of screws attached to the bottom of the stand (inside hollow area). There also two screws I believe on the back of the unit near the stand area that need to come out. The stand should come off now. But do you really want to mount it on the wall?
Oh well,
Hope this helps
Skyassoc
62helpful
2answers
Taking stand off toshiba regza tv
forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
3answers
Removal of stand
There are 5 screws in the back of the TV, immediately above the stand. From the stand, they are at the 10:00, 11:00, 12:00, 1:00, and 2:00 locations. If you remove the screw, and find a washer with the screw, then it's probably the right one. Once all 5 screws are removed, the stand slides right off the bottom. Unfortunately, once the stand is removed, the opening is left in the bottom. It's not too bad since once it's mounted to the wall, it's not high enough to see the bottom of the TV anyway. Good luck!
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
