Hi there.
You open the lid on the front/top of the printer.
Then the printer will set up the print head with the cartridges in the middle. There are white plastic clips on front of each cartridge, pull them gently towards you and the cartridge moves slightly up or you will have to pull it up. To put the new one is you must first take all the wrapping off the cartridge and twist the orange lid off the bottom of the cartridge. Make sure you put the right one in the right place. Push them gently down until you hear a "click" close the lid on the printer and carry on printing.
Iceman.
Here is a link that will guide you step by step on how to replace the ink carts on a Lexmark Printer. This is for both X4975 and X4650.
http://bit.ly/4vIE8S
Where is my ink cartridges located on my X4975 lexmark printer
Sometimes the ink
cartridge carrier won't automatically move to its loading position even when
the printer is on and the cover is open. Follow the steps below:
1. Unplug the
printer from the power source.
2. With the cover
open, hold the solid white strip that connects from the carrier assembly to the
ink cartridge carrier and gently slide the cartridge carrier to the center of
the printer.
3. Remove the
used cartridges.
4. Load the new
cartridges. Close the cover.
5. Plug the printer back to the power source.
