I have a Bosch Aquastar 2400E LP tankless hot water heater. It began working intermittently, but now has stopped heating water all together. I have checked water flow. The gas flow is still the same as it has always been. The unit has power and does not display any error codes. It almost seems like it doesn't know that water is flowing. I have checked and cleaned the intake screen. What could be the problem?
check F1 FUSE,CHECK PROGRAMMER SETTINGS, CIRCUIT BOARD BEST OF LUCK
Do you have a remote monitor? If so (REMOVE PWR) try lifting the wires on one end or the other. Restore power - open faucet and see if you get hot water.
APPEARS TO BE THE COLD WATER FLOW SENSOR
