I have a 93 Pace Arrow motor home - i have bought new batteries for it an have somehow lost track of how it was wired, as my son in law took them out an he doesnt remember how them came out.. Do you have a wireing schematic for this vehicle how the batteries are wired in place. there is 3 each an i have no idea how they were in place now as i didnt take them out> can you help >>?? thanks 'Dennis
SOURCE: pace i.3.33
get a multimeter and connect the black probe to the metal part of the closed box, connect the red probe to the middle pin hole of the sattalite input connector and tune into a channel
You shold be getting around 13v +/- 2v
OR
+18v +/- 2v
If you are not getting this your tuner has failed.
SOURCE: Fresh Water Supply
Mark that is an easy answer on my 77 pace arrow if you look on the driver side of the motorhome underneath there is a vale down there so that you can drain and blow the lines for the winter. I found out the hard way about mine the first time that i turned on the water and it poured all over the ground. Maybe you can help me where is your lp tank on yours i can't find it on mine any ideas
SOURCE: our windshield in our 1997 Pace Arrow is pulling
Aside from having it reseated professionally, you could use clear silicon sealant to close the gaps and secure the glass.
A tube costs about three dollars. You apply it with a caulking gun. If you take your time, you can fix the problem permanently and it will still look like a pro did it.
Best regards
Mike
I have a 1989 30 ft Pace Arrow with an identical problem of the batteries (3) wiring diagram I would appreciate any and all help..
Need to hook up the 2 aux batteries on our 84 pace arrow we just purchased. They weren't hooked up and the guy we purchased it from doesn't remember. Thanks.
second guessing my diagram after replacing all 3 batteries
have the same problem 3 batteries and not sure what order they need to be hooked up..
