Question about Tomtom GO 700 GPS Receiver
I am unable to connect my mobile
My mobile phone can find the tomtom but tomtom does not find phone
  • Neil Cameron
    Neil Cameron Jan 17, 2008
    i have the very same problem, it seems as though this began after a recent update, though there may be an update fix for this by now, so i'll check again when i get home (haven't used the unit for a while now, partially due to the connection problems with my phone for hands free operation).
    my phone connects via bluetooth fine with other phones and my laptop btw.
    President:
  • 4,402 Answers
Reset your device
Reset your TomTom using a straightened paper clip.
If you use a PDA, check the manual that came with your PDA to see how to reset it.
Install the latest application
We recommend always having the latest version of our application installed on your device.
See also: How to check for and install an updated version of the TomTom application?
Posted on Jan 22, 2008
6ya staff
SOURCE:
Pairing tomtom 630. it connects and works 1 time then tomtom complains about phone not responding. i did connect and after this i authorized it should work. tried with different nokia 5800 same problem....
Some mobiles require you to confirm each connection by responding to a message on the phone screen. My older Samsung phone did the same thing if I didn't hit the "accept" on the phone at the right time. My newer phone does it automatically, but it has a setting to disable the automatic connection. You might want to look at your bluetooth options on the phone for the tomtom connection and see if there is an automatic connection option.
If this helps, please rate, if not, please clarify so I can do some more research.
Thanks!
Feb 19, 2010 | Nokia 5530 XpressMusic Smartphone
I have a Nokia 6230 and a tomtom 520 go satnav. When tom tom is connected to the computer the mobile does not operate. Can you advise. I am on Sky broadband and the mobile bluetooh is set to on.
  • here" texts="Check the compatibility page here" mediasrc="|/lib/img/milan/features/253d3ed23e13994f57522f19b3139749926052c3415a2a50c198951f50.jpg">1. Check your mobile phone for compatibility.
  • 2. Switch on Bluetooth® on your mobile phone.
  • 3. Tap “Mobile phone” on the Main Menu of your TomTom and then follow the on
    copy phone book option is not available on your nokia model through tom tom device.
    check more compatibility of your phone in this link
    http://www.tomtom.com/phones/compatibility/devices.php?deviceId=19
  • Aug 19, 2008 | Computers & Internet
    Tomtom 540 will not connect to phone via bluetooth
    it may be the version of bluetooth there is a type 1 and type 2. type 2 can see type 1 but not the other way around. The fix is to get rid of the lower value item and replace it with an equal
    Jul 25, 2009 | Tomtom GO 720 GPS
    Can't connect my mobile phone to TomTom
    Since the phone worked before the visibility issue is unlikely to be the cause. Try plugging your TomTom into your computer. In the my tomtom software, select manage my TomTom. Now find and select the item about mobile phone settings and delete it. That should fix the problem when you next ask the TomTom to set up a connection with your phone.
    May 27, 2009 | Tomtom Go 730 GPS
    Tomtom go 520 can't wirelessly connect with sony ericcson k850i
    You have to use TomTom Home software to dload and install maps. DO NOT do this with your cell phone...
    Mar 22, 2009 | Tomtom GO 520 GPS Receiver
    What is the most up to date list of verizon phones that can
    Hi There,
    List of Compatible Phones can be found here.
    If you had your old voyager connect, make sure when you connect the new voyager, delete the phone on your tomtom in the manage phone option and delete the tomtom from the mobile in the bluetooth/paired devices option.
    Then try again and get the tomtom to connect to your mobile.
    Thanks,
    Pabz
    Jan 05, 2009 | Tomtom GO 720 GPS Receiver
    Tom Tom Unable to find my phone
    Most Motorola mobile phones can only remain discoverable by other Bluetooth devices for a period of 60 seconds. Occasionally this period is too short to complete the pairing process with a TomTom device.
    Go to:
    http://www.tomtom.com/support/index.php?Language=1&query=motorola&FID=3702
    Apr 10, 2008 | Tomtom GO 910 GPS Receiver
    Unable to connect to tomtom plus services
    here is the thing....not all phones are compaitlbe for the hands free calling nor the PLUS services...phones with tmobile and att&t are the only providers that are going to work...the PLUS services use a gprs wireless connection(which is needed), verizon, sprint, rogers, nextel, usea cdma wireless connection.
    Mar 29, 2008 | Tomtom GO 910
    Go 710
    Hook the Tomtom using the USB cable to your computer. You should see the Tomtom drive under My Computer as a drive letter.
    Backup all data from the Tomtom to a folder on your computer. Now select the Tomtom drive and right click, select properties, select tools, and then Check now. Allow the computer to fix any problems with the Tomtom drive. Once this is completed. Remove the USB cable and do a reset. Now turn on your Tomtom and it should work.
    Dec 26, 2007 | Tomtom GO 910 GPS Receiver
    Motorola Razr V3 will not connect to TomTom Go910
    you need to set the bluetooth to on. then set to shown to all, it will automatically find the device, and if theres a pass key you need to enter the same key on both phones to connect.
    Sep 26, 2007 | Motorola Mobility RAZR V3
    Tomtom GO 700 GPS Receiver Logo
    161 people viewed this question
    Top Tomtom GPS Experts
    LP
    k24674
    Marvin
    Marvin
    Are you a Tomtom GPS Expert? Answer questions, earn points and help others
