I just formatted and installed xp-home on my asus m2n-mx , amd athalon, 64x2.....when i try to install the soundmax audio drivers from the mother board cd it says the system does not support the hardware.....where as xp-professional sp-2 didnt have any problem.....any solution for this????/
You should install the Chips drivers or intall all the driver in series listed in your CD Utilities. Its good if you download the latest drivers of your system at www.asus.com or here: http://support.asus.com/download/download.aspx?SLanguage=en-us
You should download for 64x2 drivers.
Just formatted and installed xp-home on my asus m2n-mx , amd athalon, 64x2.....when i try to install the soundmax audio drivers from the mother board cd it says the system does not support the hardware.....where as xp-professional sp-2 didnt have any problem.....any solution
Had the same problem with the onboard sound. If you are installing WinXP browse the CD you will find a folder under the sound drivers called "HotFix"... install this into XP *before* installing the audio drivers. Moreover, you should install the audio drivers *before* anything else.
Service Pack 3 for XP includes the fix and it all installed quite nicely so long as I put the sound drivers in before the chipset drivers.
Compaq pasario 7500 AMD sound driver
SOURCE: audio driver problem
I hope this link can help you download the right driver for your motherboard.
-mrsolution
dfgds
I want all Driver for this motherboard
in xp sp-2 we face the problem audio driver problem.our pc want the audio high definitio driver but not in the m/b cd
my mic not working
WINDOW PLAYER NOT PLAYING
i have installed xp sp3
and not installed sound driver
