I need a diagram so I can take my maytag mah 24 front loader apart correctly. I have the dreaded nd code, so I just know I have something stuck in the pump. [email protected]
Hello. Are you sure of the error code? I checked the service manual and couldn't find that code listed. A jammed or clogged drain pump error is "ND". I need the exact model number to help you most accurately and provide exploded parts diagrams and part numbers. The Neptune series has a lot of service bulletins on components inside. I want to make sure I give you absolutely correct information.
Unlocking the door: Turn on the washer, but don't start any wash cycles. After a few minutes, the door should unlock itself.
Troubleshooting the "nd" message: "nd" means "no drain". Empty the (now unlocked) washer and fill the wash tub with just enough water to see a bit of water at the bottom of the tub. Run a drain cycle and check a) if it drains and b) if there are any unusual noises while it is draining. If either event occurs during the drain cycle, the drain pump may have to be repaired/replaced.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Hope your filter is clean. Don’t wait for the
machine to jam to
look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and
other such
things can be stuck around the inside tub of your washer. Try this
product, it
works great on all front loaders. Use very hot water with the Affresh
pellet
with no clothes and run the machine through a cycle. Also helps with any
stagnant water smells. Put the Affresh
pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the
free help,
can't you. Thanks.
i also have this problem. to get the door to unlock, just unplug the washer and it should open in a min or two. you will hear a click. you may have a mini flood but at least you can get your cloths out and bail out the water. my problem started when i began using a new detergent from Tide called total care. Still tying to get the pump to work.
you need to remove the front cover by removing th escrews holding on the door hinge nad 2 other screws oppisite the hinge, after taking off screws the front "u" shaped panel will pull foward and off( hoeld on by 2 clips along the bottom. the drain pump is located right back corner of machine..ill assume that the machine is still full of water so youll need ot **** out as much as possible before removing the hose connected to the pump. theris going to be some water no matter how much you remove nut might as well get as much as you can. youll either find debris in hose, or debris lodged in imoeller of pump, even seen coins standing in the plastic hosing preventing flow of water.VERY< VERY rarely bad pump ussually just a clog.IMPORTANT UNPLUG UNIT FIRST LOTS OF LIVE WIRES UNDER HERE
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Yeah I need that too! That is what I am looking for.
