Cell Phones Logo
Posted on Nov 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to add an earth (ground) symbol int word document
Anonymous
Level 3:
President:
  • Master 995 Answers
  • Posted on Nov 10, 2009
Anonymous
Master
Level 3:
President:
Answers
995
Questions
Helped
293872
Points
3215
Insert a an earth ground picture.
5helpful
3answers
Will it hurt anything if I add a ground wire from my alternator to the chassis on my 2000 lincoln ls?
no. as long as you ground it by a mounting bolt. Might be pointless though. For your alternator is already grounded to the chassis. the alternator is grounded directly to the engine, the engine is grounded to the chassis. therefore your alternator is grounded already to the chassis.
2answers
I need wire colors for CB microphone its a TRC
ALTAI PWR MIC - black/braid= earth, red=RX, white=TX, Yellow=MODASTATIC - blue/braid=earth, black=RX, red=TX, white=MOD, Yellow=Spare
SIRTEL ECHO MIC CBE 2002 - black/braid=earth, blue=TX, white=RX, red=MOD007 POWER MIC - brown/braid=earth, green=RX, white=TX, blue=MODSADELTA EC 980 - braid=earth, green=RX, brn=TX, white=MOD
or braid=earth, black=RX, blue=TX, white=MOD
1helpful
3answers
1996 ford ranger wipers wont work fuse ok,new wiper motor,new switch, new relays. what else is there?
Do you have int wipers? If so check the int module its under the dash right side of the steering column I believe. Specifically check the solder joints.
Dear Sir , If you start copying a Class 10 / 11
I understand the pain and how difficult it is to work on a science document!!!!!!!!!!!!
By the way if you are using the office suite applications such as Word 2007 or word 2010, you can insert the symbols easily.
To insert a symbol or special character into your document, follow these steps in Word 2007:
1. Position the cursor where you would like to insert the symbol or character
2. Open the Insert ribbon
3. Click Symbol in the Symbol section
4. A menu will appear with a small selection of symbols
5. If you don't see the symbol or character you'd like to insert, click More Symbols
6. Use the controls to select between symbols and special characters. Additional tools on the symbols tab will help you expand or narrow your selection
7. When you find your symbol or special character, click it and then click Insert
8. When you're done, click Close
The symbol or special character will appear at the appropriate place in your document.
Hope this helps!!!
Well, I am helpless regarding developing a keyboard with all those scientific symbols,.LOL
W
1helpful
I'm replecing the power cord on my Kenmore
The earth wire ( ground) is only used to earth metals on/in the appliance.
If the appliance is double insulated ( I suspect it is ) you can safely cut off the ground wire.
You can identify the system used by 2 squares symbol, one inside the other which means its double insulated
I need a complete workingsource code written in
This is a simple source code for Simple calculator in Java using RMI
//mathServer//
import java.rmi.*;
import java.rmi.Naming.*;
import java.rmi.server.*;
import java.rmi.registry.*;
import java.net.*;
import java.util.*;
interface mathInterface extends Remote
public int add(int a,int b) throws RemoteException;
public int subt(int a,int b) throws RemoteException;
public int mult(int a,int b) throws RemoteException;
public int div(int a,int b) throws RemoteException;
public class mathServer extends UnicastRemoteObject implements
mathInterface
public mathServer() throws RemoteException
System.out.println("Initializing Server");
return(a+b);
return(a-b);
return(a*b);
return(a/b);
public static void main(String args[])
try
mathServer ms=new mathServer();
java.rmi.Naming.rebind("MathServ",ms);
System.out.println("Server Ready");
catch(RemoteException RE)
System.out.println("Remote Server Error:"+ RE.getMessage());
System.exit(0);
catch(MalformedURLException ME)
System.out.println("Invalid URL!!");
//mathClient//
import java.rmi.*;
import java.awt.*;
import java.awt.event.*;
public class mathClient extends Frame implements ActionListener
Button B1=new Button("Sum");
Button B2=new Button("Subtract");
Button B3=new Button("Multiply");
Button B4=new Button("Divide");
Label l1=new Label("Number 1");
Label l2=new Label("Number 2");
Label l3=new Label("Result");
TextField t1=new TextField(20);
TextField t2=new TextField(20);
TextField t3=new TextField(20);
public mathClient()
super("Calculator");
setLayout(null);
l1.setBounds(20,50,55,25);
add(l1);
l2.setBounds(20,100,55,25);
add(l2);
l3.setBounds(20,150,55,25);
add(l3);
t1.setBounds(150,50,100,25);
add(t1);
t2.setBounds(150,100,100,25);
add(t2);
t3.setBounds(150,150,100,25);
add(t3);
B1.setBounds(20,200,80,25);
add(B1);
B2.setBounds(100,200,80,25);
add(B2);
B3.setBounds(180,200,80,25);
add(B3);
B4.setBounds(260,200,80,25);
add(B4);
B1.addActionListener(this);
B2.addActionListener(this);
B3.addActionListener(this);
B4.addActionListener(this);
addWindowListener(
new WindowAdapter()
public void windowClosing(WindowEvent e)
System.exit(0);
public void actionPerformed(ActionEvent AE)
if(AE.getSource()==B1)
sum();
else if(AE.getSource()==B2)
subt();
else if(AE.getSource()==B3)
mult();
else if(AE.getSource()==B4)
div();
public void sum()
int i=Integer.parseInt(t1.getText());
int j=Integer.parseInt(t2.getText());
int val;
try
String ServerURL="MathServ";
mathInterface MI=(mathInterface)Naming.lookup(ServerURL);
val=MI.add(i,j);
t3.setText(""+val);
catch(Exception ex)
System.out.println("Exception:"+ex);
public void subt()
int val;
try
val=MI.subt(i,j);
t3.setText(""+val);
catch(Exception ex)
public void mult()
int val;
try
val=MI.mult(i,j);
t3.setText(""+val);
catch(Exception ex)
public void div()
int val;
try
val=MI.div(i,j);
t3.setText(""+val);
catch(Exception ex)
mathClient MC=new mathClient();
MC.setVisible(true);
MC.setSize(600,500);
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
