The only computer with limited access are wireless, correct? Make very sure your secutity settings are correctly set, router and computer. This should fix your problem.
Did you try to install the drives first? try that. see if the laptop gets an IP from the router (by default 192.168.x.x).
I would also try to plug the laptop directly to the router and see if it works (with network cable plugged between the two)
