What MSI board in particular? At any rate, it would run like molasses through a carbon filter; get some newer hardware from the trash or re-use programs or by sacrificing money to the Windows 7, Videocards and Systems sellers.
More detail in when the error popped up might be handy too; if you got the message before the Win7 DVD was booted, it's because you didn't go into the BIOS and tell it to boot from the DVD instead of your blank HD. That is great that you can change that, but to save some money and time you might buy a carbon filter and some molasses....
What you can do is attempt to repair the system using System Restore or startup repair. I would suggest trying startup repair first.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista or Windows 7 installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Hope this helps
Ray
First please refer to the following thread to see whether it helps.
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=796452&SiteID=17
I know that you are unable to start the current vista operation system and getting the error 0xc00000e9; the issue can be caused by the damaged system files or hardware device. You might first follow the steps below to exclude the possibility of system corruption.
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
Before going any further, please help to confirm the following three points:
1. Does any other error message appear when starting the computer?
2. Did the computer start properly before?
3. Have any changes been made on the computer recently, such as an installation or upgrade?
The issue can be caused by many factors, such as incorrect BCD entries and incompatible hardware or software.
Based on the current situation, I suggest trying the following methods to troubleshoot the issue.
Method 1: Startup Repair from the Windows Recovery Environment (WinRE)
2. Press a key when the message indicating "Press any key to boot from CD or DVD ..." appears.
7. Click the operating system that you want to repair, and then click Next.
Can the computer be started now?
If the issue persists, I would like to confirm if System Restore was enabled before.
If so, we can try to restore the system to a state when your computer worked properly in WinRE.
Method 2: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Instert the Windows Vista installation disc into the disc drive, and then start the computer.
"Stop: 0x000000A5" error message typically indicates that the computer BIOS is incompatible with the Advanced Configuration and Power Interface (ACPI) standard that is supported in Windows 7. However, this error can also occur because the computer hardware, the peripherals, or the drivers for those devices are incompatible with Windows 7.
1. Insert the Windows 7 installation disc into the disc drive, and then start the computer.
Refer the following link for more information:
http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7
Thank you for the post.
I suggest trying the following methods to troubleshoot the issue:
Method 2: Rebuild BCD
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec /RebuildBcd , and then press ENTER.
Method 3: Use the Windows Recovery Environment (WinRE) to run System Restore ============================================
Note:I just pasted this answer from other person cause its very long when i will wrote it and i think the better one than my explanation.
regards,
mastergani
