Nokia 3110 Cellular Phone Logo
Posted on Nov 10, 2009
Memory card not formatted model 3110 - Nokia 3110 Cellular Phone
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 10, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1136
Points
12
I'm having 1 GB micro sd memory card for my mobile nokia 3110c ..... and it is password protected ... bit actually i have forgotton the password .... i have tried also by connecting the data cable but in nokia pc suite its showing that there is no memory card ...., i had also tried thru card reader's but its not opening ./... is there any solution to unlock this card data lose in doesn't matter... plz help me unlock memory card
5 Related Answers
Anonymous
  • 39 Answers
  • Posted on Aug 27, 2009
SOURCE: while i insert the memory card its showing format the memorycard
whenever u want to format any thing ,use quick formating otherwise it will creat a problem ok ,try to format the memo card by connecting it with ur computer
aysaam
Resolution IT Dubai
  • 541 Answers
  • Posted on May 30, 2009
SOURCE: format code for nokia 3110 classic
Hi Friend,
There are 2 ways to format ur nokia 3110c
Step1.
1.hard reset
hard reset using this code *#7370# (ALL DATA WILL BE DELETED)
Step2.
1: Turn off your mobile
2: remove your memory card
3: Turn it on again
4: Go to Menu then Applications
5: there will be 2 folders games and collection
6: open each one seperatley and delete everything inside them>
7: Turn your phone off replace the memory card then Turn it on and have fun no more problems try it
Regards,
Ayyasam
Anonymous
  • 283 Answers
  • Posted on Jul 28, 2009
SOURCE: can i lock the memory card nokia 3110 clasic
yes you can lock it. go to gallery, then sellect mmory card, then option then select aet password. tnx
Anonymous
  • 763 Answers
  • Posted on Jan 07, 2010
SOURCE: how i can format memory card in nokia 3110 classic
Type *#7370# and then click yes..it may ask you for pincode.
the default pincode is 12345 (if you do not change it)
then you are finish.
For more information you can always refer to the manual.
Here is the manual download link.
Open the file with Adobe reader ot Foxit reader.
http://nds1.nokia.com/phones/files/guides/Nokia_3110_classic_UG_en.pdf
Anonymous
  • 264 Answers
  • Posted on May 31, 2010
SOURCE: 3110 Cellular Phone: memory card not formatted, operation failed...
This is a problem due to the memory card IC.The IC has to be replaced .Better contact service centre.If you are familiar with Mobile Circuits you can follow the instruction in the following diagarm.this will solve the problem
2answers
I forget memory card passward 3110 nokia
hi gud mrng,use nokia higher models like 5800 or 5233 insert ur memory card and go to file manager select memory options format memory card problem will be solved
Please tell me how to formate memory card in mobile Nokia 3110?
Try: Menu > Gallery > The memory card should be highlighted so press options > Format Memory Card
If you cannot see the memory card in the gallery then it may not be compatible with your phone or of a larger capacity than what it can accept.
Good morning sir, my nokia 3110 classic recieves viruses from where i dont know. If i put my memory card in the phone and dont use it for along time my memory card gets affected.
VIRUS/FORMAT
First: better use kasperaskey anti virus.
If your desktop pc or laptop has antivirus,
have your pc scan your fon memory through bluetooth, or usb cable
OR:
If you have Virus On mobile
1 - remove memory card.
2 - dial *#7780# or *#7073*
3 - It format your Phone
4 - Format memory card.
and enjoyyyyyyyyyyyyyyyyyyyyyy
13helpful
When i click in memory card option,memory card not formatted shown,what will i do..........
select your memory card -> options -> format memory card option.
After the format you can use your card to store files as you wish.
Note: Format will erase all the existing files from your card
Thanks
20helpful
2answers
I forgot my memory card password(MicroSD 512 mb Nokia 3110c)
i have nokia 3110 classic mobile. the memory card is nokia. i set password for my memcard. i had a software problem with my phone. so i gave for installing sw for my phn. after installing the software, when i opened my mem card it asked password. but i forgot the password. so i wnt to format it. but for formatting also it asks password. pl solve my problem
212helpful
11answers
How to delete my memory card password in Nokia 3110 .It is 256mb
My 3110c was hanging after opening and it cant be open with memory card inserted
its common with that model you just need to format your phone and memory card and keep the file structure clean to format your phone use *#7370#
13helpful
Format code for nokia 3110 classic
Hi Friend,
Step1.
1.hard reset
Step2.
3: Turn it on again
Regards,
Ayyasam
How to format nokia 3110 completely
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
