E-Machines eMachines Desktop PC Logo
Posted on Nov 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I restored my computer to an earlier date and after that it stopped working when the screen comes up it says something like INTEL and a bunch of stuff and then it says DECOMPILATION or DISASSEMBLY PROHIBITED can you tell me how to fix it?
Anonymous
Level 3:
  • Master 557 Answers
  • Posted on Nov 10, 2009
Anonymous
Master
Level 3:
Answers
557
Questions
Helped
196593
Points
1635
Try opening the computer in safe mode (F8 key). as soon as the computer starts. If you can open in safe mode you can undo the restoration, if not you have to do a complete reinstall of windows.
I have done something and I can not apostrophe a word. What did I do wrong
Ensure that the keyboard is set to the correct region and language.
If you are very troubled by the problem and cannot cope just recover the system files to an earlier state, it is called a system restore. Select a date in the restore facility when your computer was tunning correctly, you will then be directed to ok and then finidh the process.
Do these and the machine will be set to the earlier state when all was functioning correctly.
Hard disk stop
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
3answers
My computer did a driver update and ever since my volume has gone down ? what can i do to make it go back to be louder ?
you can try system restore which will restore your computer to an earlier date.
go to start->all programes->accesseries->system tools->system restore.
press next on the system restore window...select any date of your choice when thw computer was working..click next and then click finish..it will do the system restore..restart the computer and then check..if you find helpful...please rate thanksvikasbharti8_1.jpg
My computer is a toshiba, with windows 7, and it recently quit working and i need it for school! it will turn on but before it gets to windows, a blue screen shows up with a bunch of writing such as an...
restart the computer in safe mode and then click start and type system restore in the search box follow the instructions to restore to a earlier date when the computer was working ok
if this info helped please vote for me
2answers
My computer keeps going back to the screen asking
Reboot the computer, on start up, press Alt +F10 and set your computer back to a earlier date or do complete restore, hope this helps!
2answers
Featuremanager corruption pop up was appearing on my desktop
inorder to fix this issue. use system restore. click start menu - all programs - accessories - system tools - system restore. select a date where you think your computer is working fine then restore the computer to that date. this will solved the issue
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
I was having a problem with my Outlook Express and I tried to restore my system to an earlier date. The computer screen went blank but the tower was still on. I turned it off and turned it back on and now...
The system restore probably undid something really essential for the computer to work properly. Try hitting F8 when the computer is booting up, boot into safe mode, log in as admin and try to undo the last restore you did.
Dead dell touchpad x(
Have you tried System Restore? If not familiar... Start Button ---> Help ---> System Restore ---> "Restore my computer to an earlier date" --> choose an appropriate date, maybe a few days earlier than the problem.
Re-boot and see if works! If you are ceratin that the problem arose simply from hibernating, then restoring should do the trick!
Hope this helps!
-- RT
PS - Don't forget to vote!
Need registry key to to install printer
Assuming you are running Windows XP, you may be able to repair this issue if you "restore" your computer to an earlier date.
This is a process by which Windows remembers a time when your computer functioned properly, and sets your computer to those settings. Most of the registry problems can be fixed in this manner.
To access Restore feature, click Start and find Programs, then Accessories, then System Tools, then System Restore.
A window should open that asks if you would like to create a restore point, or restore your computer to an earlier date. Choose this later option.
The next screen should show you a calendar. The dates which are bold are dates that you can choose to restore your computer.
You may not fix the problem on the first try; so choose the most recent bold date, and restore. If the printer still will not install, repeat the process with the next older date.
Unfortunately, if this process does not allow you to repair your computer's software, a reinstallation of the operating system may be required.
Good luck....tony
1helpful
4answers
Just bought an acer aspire ax1200-b1581a.it worked fine for a few days now it will pop up there was a problem with the internet and shut the itnernet down,it started out going blue screen and at the bottom...
I think the problem is related to virus. Try restoring your PC to an earlier date 9 a date when it worked fine). You do this from Start-> Programs -> Accesories -> System Tools -> System Restore. Select
Restore my computer to an earlier time and Click Next. A date calender will appear, select the preferred date and click Next twice. The system will automatically restart when restoration is done.
If u are not abe to run System Restore then you need to enter safe mode by pressing F8 during booting and selecting Safe Mode from the menu that appears. In safe mode you will be asked a question, you have to select no, and system restore will start
If restoring your pc does not solve the problem then you may need to reinstall your OS.
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
