The oven temperature sensor is bad. Open the oven look in the back wall of the oven on the top right or left side.There will be a 3 inch piece of metal sticking out,slightly smaller than a pencil thickness. Unplug the range. Remove the screws from the sensor and pull it out to disconnect the wiring plug. Install a new temp sensor.
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
