Panasonic KX-TG5632 Phone Logo
Posted on Nov 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I actually have a KX-TG5633. I have lost the owners manual and want to turn off the ringer on the base station and handset. I work nights and try to sleep during the day but the phone continuously rings awakening me. Thanks.
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Nov 09, 2009
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3073067
Points
27242
Manual for Panasonic KX-TGD 530
Duplicate question Deleted. Refresh page to see it published.
KX-TGD530
Panasonic https://help.na.panasonic.com > telephones > kx-tgd530
Model includes: 1 Cordless handset base unit. Base unit part # KX-TGD530, handset part # KX-TGDA50. Shop Panasonic. Operational Inquiries.
Operating Instructions
Panasonic https://help.panasonic.ca > ALL > KX-TGD510
Feb 22, 2018 - Press MDN or MCN repeatedly while ringing. R To turn the ringer off, press MCN repeatedly. Base unit*1. *1 KX-TGD530 series. Press ...
52 pages People also a
Why does my Panasonic KX-TGM420 go straight to voice mail?
Voicemail is a service of your telephone company. If your calls are going to voicemail, check the settings following the directions for the service. If the answering system is getting the calls, then check if the KX-TGM420 handset(s) and base are set to a ringer volume of 0. You can change this from either the base or a handset by pressing the + button while the phone is ringing. Otherwise, when the phone system is in standby (no calls in or out), press # 1 6 0 on a handset or * # 1 6 0 on the base. Then set the ringer volume on the handset (0-6) or base (0-10). This is the equivalent of pressing menu and navigating through the menu (Menu > Settings > Ringer Adjustment > Ringer Volume (Incoming)). You can also turn off the ringer by pressing and holding 0 on the handset and Ringer Off on the base. See pages 33 and 44 of the manual, link below.
I hope this helps. The manual is available here: https://help.panasonic.ca/viewing/ALL/KX-TGM420/OI/TGM420_PNQX7794YA/TGM420_PNQX7794YA.pdf .
How do I get my older Panasonic hand set phone to ring on an incoming call?
The KX-TGA401C handset works with the KX-TG401x, KX-TG403X and KX-TG651x phone systems among others. If you have the appropriate base, see the suggestions below.
Does your handset read Ringer Off? Try setting the ringer volume. With the phone system in standby (no calls in or out for any handset), press Menu. Navigate using the Up/Down arrows to Initial Settings. Press Menu/OK. Navigate to Ringer Settings and press OK. Press OK again to enter the Ringer Volume sub-menu. Use the Up/Down arrows to set the ringer volume and press OK to save. Press Off to exit the menu system.
The other possibility is that the handset is not registered to the base. Note: only 6 handsets can be registered to the base. If you previously registered 6 handsets, you need to deregister some of them.
To register the handset, hold the handset near the base since you will need to press buttons on both. Press Menu on the handset and navigate to and enter Initial Settings. Navigate to Registration and press OK. Navigate to HS Registration and press OK. On the base, press and hold the Locator button for 5 seconds and the registration tone sounds. Press OK on the handset you are trying to register. If all the registered handsets start ringing, you triggered the Locate handset function. Press the Locator button again. Then do the press and hold step again. Only press OK on the handset when you hear the registration tone.
You can find the manual for the KX-TG4011 here: https://shop.panasonic.com/support-only/KX-TG4011N.html . The direct link to the manual is https://ftp.panasonic.com/telephone/om/kx-tg4011_mul_om.pdf . See page 21 for the directions to set the ringer volume.
I hope this helps.
(You can't register a handset to an incompatible base. The communication protocols don't work.)
Turn ring on
Do you mean the Panasonic KX-TGA470 handset? The KX-TGA470 handset is the included handset for several models of Panasonic cordless phone systems, including the KX-TG7732. When the ringer is off, the handset should show a bell with a line through it. To adjust the ring volume, press Menu on that handset when the phone is in standby. (The base and handsets are not in use.) After pressing the Menu button, type # 1 6 0. (Alternatively, use the arrow keys to navigate to Initial Settings and press the soft key for Select. Navigate to Ringer Settings and press Select again. Go to Ringer Volume Handset and press Select once more.) Use the arrow keys to select a value between 0 and 7. 0 will keep the ringer disabled. Press the soft key for Save. Press Off to exit the menu.
You can also adjust the ringer volume on that handset by pressing the Volume Up key while the phone is ringing at the base and other handsets. You can adjust the base ringer volume by pressing the + or - keys when the phone is ringing. Alternatively, press Menu # * 1 6 0 from any handset. Note: this phone system also has a silent mode. Press Menu # 2 3 8 to enable or disable the feature. When this is enabled, the handset will show an icon with several Z's.
You can find the manual on the phone system page: https://shop.panasonic.com/support-only/KX-TG7732S.html . The current link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tg7731_mul_om.pdf . See pages 23 and 35 for the ringer volume adjustment. See pages 35 and 40 for information on the silent mode.
I hope this helps.
Can't turn ringer on cordless panasonic KX-TGA402C phone.How do i turn it on?
KX-TGA402C is the included handset for a Panasonic cordless phone system like the KX-TG4011C. You should be able to adjust the ringer volume from the Initial Settings menu. With the phone system in standby, press Menu on one handset. Use the Up/Down arrows to locate the Initial Settings. Press OK. Then select Ringer settings and press OK. Select Ringer Volume and press OK. Use the Up/Down arrows to set the desired Ringer volume and press OK to save. Press Exit to leave the menu system. Alternatively, you can adjust the ringer volume by pressing the Volume Up/Down buttons while the phone is ringing.
The manual for the KX-TG4011 is available from Panasonic here: ftp://ftp.panasonic.com/telephone/om/kx-tg4011_mul_om.pdf . If the above steps aren't working, check that your handset and phone base are properly paired (registered handset). Also check that the base has power and connected to a working phone line. Also make sure that the handset is fully charged.
I hope this helps.
Turn ringer back on Panasonic cordless kxtg101s
The KX-TG101s isn't a model that I recognize. Do you mean the KX-TGA101 handset? If so, that handset goes with the KX-TG1031 base.
If this is the right handset, make sure that the entire phone system is in standby. Press Menu/OK and navigate to Handset Settings with the Up/Down arrows. Press Menu again and navigate to Ringer settings. Press Menu and navigate to Ringer Volume. Press OK and use the up/down keys to set the desired volume. Press OK and then Off to exit the menu system. You may also want to check the Ringer tone in the same Ringer setting menu. The tone may not be set to one that you hear.
See page 24 of the manual, which is currently available from ftp://ftp.panasonic.com/telephone/om/kx-tg1031_en_om.pdf .
I hope this helps. If you still don't hear the phone ring, you may need to check your phone wiring and the base. I often check phone wiring with an old-fashioned wired phone.
Have a Panasonic KX-TG1061C with 3 handsets. Handsets work perfectly. None of corded base unit buttons work.
to turn off night mode http://www.manualslib.com/manual/793900/Panasonic-Kx-Tg1061c.html?page=25
do not think night mode would cause your problem.
check dialing mode #120
TONE ?
When you unplugged the base unit did you pull out the ac adapter for about 30 seconds to reset the base unit ?
Phone issues.
1st) you must identify the ranking order of your handsets. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset. Go to the main base cradle. On the bottom, where it says "locator" press the "select" button until you get the desired phone rank needed. H1,H2,H3 etc... Then, press and hold the "call" button, under "intercom". (The charging light should start flashing) Now, go to your handset and press the "OK" button on the top upper right corner. At this point, your phone should be working!
If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support. PS: your handset may show model KX-560B, but your main cradle base will show the actual phone model listed as KX-TG5633
3helpful
7answers
Ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
