Jet 708100 Jwts 10 1 1/2HP Workshop Table Saw Logo
Posted on Nov 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blade on saw not in line with table - Jet 708100 Jwts 10 1 1/2HP Workshop Table Saw
Norman Al-Anbar
Level 3:
  • Master 630 Answers
  • Posted on Nov 09, 2009
Norman Al-Anbar
Master
Level 3:
Answers
630
Questions
Helped
164760
Points
1759
The blade may be curved and need replacement check with a level and see first
3answers
How can I change blades in some woodworking tool?
What kind of tool? Do you have a photo?
2answers
10 inch table saw blade not square with table
Sounds like the bolts that hold the motor assembly on the table may be loose allowing the blade assembly to move. Look underneath the table and clean out all the dirt and loosen all the hold down bolts and realign the blade and tighten back up.
How to adjust the blade at exact 90 degre
Use a carpenter square, place the square on the table top with the blade up right, adjust the tilt of the table saw blade until it is exactly parallel to the blade of the carpenter square. Check the blade in several places as the table saw blade is sometimes warped. Try to adjust until a happy median is obtained.
I am getting very bad kickback about 3/4 the way through my cuts. I have a new blade on the saw. I dont really know how to troubleshoot this.
Possible that the fence you are using is not on a true parallel line with the blade and as a result it is causing the wood to pull into the blade causing kickback. I would do an alignment procedure on the fence to make it as true to the blade as possible.
3helpful
Can you run a dado blade on this saw?
The 15 amp 3 hp motor has plenty of power to handlee dado sets and you can purchase a dado blade insert for the saw on line from multiple resources
How do you align the motor on an older (JET) JWTS-10 Table Saw. The manual does not go into it and I have looked inside the saw and can't find any way to align. The rear edge of the blade is out of...
Remove the drive belt, loosen the motor base bolts on the motor and put a straight edge on the outside edge motor pully rotate the motor till the straight edge lines up with the outside edge of the saw blade pully then retighten the motor base bolts and replace the drive belt.
Problem with 10" craftsman table saw
Your adjustment should be done on the rip fence which will align it to the blade for strait non binding cuts.
2answers
New table saw, timber runninig off away from guide, saw blade running its own line,do i need to reset the guide.
The guide is called a fence. The fence should be positioned to the right of the blade. When using the fence, the largest part of the board goes between the blade and fence. Fences are typically have some relief toward the end, so you don't get the blade cutting on it's way down, and then cutting again on it's way up.
Delta saw model no. 28-245 saws a taper form top of wood to bottom why does it not saw a stander line Delta saw model no. 28-245 s/n 91B1335
Sounds like your table is tilted. Put a small square on the table against the blade, then adj the table to it. If that is not it, then the blade guides are off up and down, back off all the guides, wheels, turn the blade by hand, get it tracking in the center of the tire, then bring the bearings up the blade, don't push it , just touch it, then bring in the guides, again, make sure it doesn't push it, the guides stop it from going off, it should track by itself. Hope this helps.
Feb 05, 2010 • Delta Saws
After inserting a blade in the quick lok, the blade does not line up straight with the guide. The blade goes beyond center.
The blade lines upaccording to the rotor shaft and has nothing with the guide except for the fact that the table has been droped and bent out of place or has been tweeked out of place somehow, usually hitting the floor from the table top causes this. Loosen the table screw to see if you can get it back in place and square it back up, hope this helps, good luck!
Top Jet Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Jet Saw Expert? Answer questions, earn points and help others
