If you formatted your desktop, you will have to partition and reinstall Windows...
Hi, it seems Windows is not installed well or the hard disk could be faulty, the first step could be to check data and power cables among motherboard and power supply to hard disk and if that's OK, try to do a clean Windows installation, if this fails maybe the hard disk has the boot sector physically damaged and it's better to replace it.
SOURCE: hard disk problem
Change the other HDD to either Cable Select or SLAVE.
Then make sure you partition it correctly, Windows does a decent job at it.
Right click on My Computer, go to Manage, then under storage, click on Disk Management; you should see the HDD here.
SOURCE: samsung 80 GB IDE
hi, sounds like a faulty hard drive i would suggest downloading this http://www.seagate.com/www/en-us/support/downloads/seatools/ even though the test software is for seagate it still works for all drivers.
boot from the floppy disk it creates and it will test the drive..
Happy New Year
John
SOURCE: problem in hard disk
control panel
computer management
disk management
select the disk and iniatlize by right clicking.
SOURCE: Samsung USB hard disk not working
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external ,
go to Start-Control Panel-Administrative Tools-Computer Management-Disk
Management , and see if your external drive is listed here with your
local drives. If it is listed , right click on the drive and change the
drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your
computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your
computer case or another external case.If the drive works , the problem
is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
The
latter is the easiest to diagnose , does your external light up at all
when you plug in the power? If not , then this is probably your problem.
On the bottom of the adapter is a label which you will be able to use
to have a new adapter made at your local electronics shop and this will
cost about $30 max. They will also be able to test the adapter with a
clamp meter to see if this is really the problem and this should be
free.
The second component you want to test is the USB cable. If
you have a printer , swop out the cables and see if your printer
functions normally. Most externals use the same connector so you should
be able to test it in this manner. If the cable works go on to the last
step. If the cable is defective , replace it with a new one which you
can find for about $10 at most electronics and chain stores.
The
last component to test is the circuit board. This is a bit of a grey
zone as you probably won't be able to spot the blown component unless it
failed really badly. With the casing already opened , locate the
external's circuit board and check to see if you have any blackened
components or fluids leaking from some components. If all the other
components of the external worked perfectly , then this is the faulty
part. It is not really economical to replace the circuit as most of the
time it is out of production by the time you need to replace it and it
still costs a lot even if it is available so if your drive is working
perfectly when connected via sata or IDE on your computer , the best is
to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
SOURCE: eveytime i restart my pc, the blue promt says
Dear Ahrjae,
You are Toast! The last thing a technician wants to do is format a hard disk. A good format erases everything (all the software and corrupted software) and the hard-drive has the smallest amount of information on it (software) waiting to be shaped by the DVD's (Software) you are going to load it up with.
If you have a bad hard-drive you need to determine if it is a software problem or a hardware problem. Some times it is both. If it is software you can delete the program and re-install it. if it is a hardware / software problem you can run a scandisk program and other utilities to fix bad sections on the hard-drive. Electrically cut off bad sections so no memory 1's and 0's will be stored on bad sections of the magnetic hard-disk. Then you can delete bad programs and re-install them.
Sometime the hard-drive fails due to hardware problems. My favorite story is the comparison of the pickup head gliding over a hard disk (metal) and occasionally crashing to an airplane flying 600mph over the earth. Where the airplane would be destroyed if it hit the earth, in the hard-drive the pick-up head gouges out parts of the metal disk.
So your solutions: Buy a new hard drive and format it or take the unit in to be repaired. Hope you have made your restore disks.
regards,
Digital Denizen
