SOURCE: remote codes
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just
yet. Please post back as to what steps you took, results, etc, and I will try to
assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Most remotes have a "Search for Code" or learn function. However, since Comcast currently supports 8 different types of remote controls, your best bet is their website. This link takes you to all of the remotes they currently support, find your remote and click on the View Manual link next to it.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
More than likely you will have to use the "Search for Code" option, as I did not see your particular TV brand on the few that I checked.
Follow these steps to program the remote control.
NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
no remote works for this tv anyone have any good codes
sameproblem have brought 3 different remotes with no sucess
I have direct TV and I have the same problem. I have a Haier brand Television and I cannot record the tv functions(on, off, volume) to the Direct Tv Universal remote. I have gone through the remote setup but Haier is not listed as a tv with the codes.. HELP
i need tv codes
I have a Haier TV. The remote broke and I looked to replace it with a Universal remote, however, no code was listed for this type of TV. Is there a special code for this type of TV?? Can I purchase a new TV remote?
i have a haier tv but a all for one remote. need the program code
I am unable to turn my tv off and on. I don't have a code for the comcast remote.
REMOTE CONTROL RC24993-C 1120 HOW TO ACTIVATE
