Computers & Internet Logo
Posted on Nov 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot load valid copy of Office 2003, Adobe 7.0 pro, quickbooks
Office 2003 and adobe 7.0 pro both give ''not valid'' error on new compaq vista ? also quick books same problem.
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Nov 09, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557671
Points
31058
If it is a "new" computer, and Office 2003 and Adobe 7.0 Professional came "pre-installed" on your computer, then take everything back to where you bought the computer, and get them to assist you. If they are at all a "responsible" retailer, they will support the products that they have sold to you.
If you have your own copy of Office 2003, and you are trying to install it, then start Vista's "Program Compatibility Wizard", and select that you want to install an "XP" program, and select the CD-ROM as the "source" for the software that you want to install.
Vista will wrap an "envelope" around Office 2003, to emulate a Windows XP environment.
Same for Quickbooks and for Adobe software.
2helpful
I need validation code for Quickbooks 2010. The License # 3226-1853-4637-229 Product number 186-387
Hi Rajikumar,
I'm working as tech support specialist for intuit quickbooks, Unfortunately the quickbooks you have is known pirated copy,
In intuit quickbooks, we cannot provide you a validation code for that,
we highly advise to our customer to have a legitimate copy of quickbooks by calling us at 888-222-7276.
or if you want you can get a legitimate copy in costco, office depot, bestbuy, walmart.
i know this answer will frustrate you but moving forward dont purchase quickbooks in a third party website.
Thanks,
She Morillo
tip
How to activate office 2007
Office Genuine Advantage (OGA) is another anti-piracy initiative by Microsoft on its popular business productivity product – Microsoft Office XP, Office 2003 and Office 2007. Similar to Windows Genuine Advantage (WGA), OGA requires users of the Microsoft Office software to validate their installed copy of Microsoft Office in order to download files from Microsoft Download Center, access updates or hotfixes from Office Update, and receive special offers for genuine users.
OGA is not to be confused with Office Product Activation that is mandatory required to during the installation process in order to use the Office software whereby users enter a serial product key that is validated online over the Internet or by phone by Microsoft to confirm that the product key has not been used on more personal computers than are permitted by the Microsoft Software License Terms. To crack Office XP/2003/2007 activation, you need a key generator that provides volume license key (Guide: How to change Office 2007 product key).
If you’re using a keygen-generated product key or publicly available leaked Office 2007/2003/XP serial number, especially the volume license key (VLK) that requires no activation when used, most of the keys no longer able to pass the OGA genuine validation test anymore with the following error message (Office 2007 as instance):
office-fail-validation.jpg This computer has failed validation.
Microsoft Office Enterprise 2007: Validation Failed
The product key used to install Office is not valid. It has been identified by Microsoft as a false key used with counterfeit copies of Office.
[0x80180108]
It’s likely that users who failed validation check may continue to use Microsoft Office as per normal and use Microsoft Updates to update critical patches. However, if you want to download add-ins, updates, templates, samples and tutorials, Smart Tags, Language Interface Packs and Software Development Kits (SDK) that require Genuine Office validation, you won’t be able to do so.
To bypass or crack the Microsoft Office 2007 and Microsoft Office 2003 OGA genuine validation, follow these steps:
  1. Install and activate Microsoft Office 2007 or other version of Office. If you intend to use the key-gen, you must install Enterprise edition.
  2. Download the patched ogacheckcontrol.dll.
  3. If you never validate your copy of Office, go to Genuine Microsoft Software web page, and run the Office Validation Assistant by using Internet Explorer (not Firefox as it will use different version of ActiveX component). This is to install the components required for Office validation. If you fail the validation – Office not genuine – simply ignore the message.
  4. Copy the cracked ogacheckcontrol.dll to the following location: Windows XP and Windows Vista (32-bit): \Windows\System32\
    Windows XP and Windows Vista (64-bit): \Windows\SysWOW64\
  5. Attempt to download Office files that require validation again. All downloads should work now.
The OGA Check Control crack works on Office 2007 Enterprise Edition, Office 2007 Blue Edition, Office 2007 Professional Edition, Office 2007 Pro Plus, Office 2007 Standard Edition and all Office 2003 Editions.
If you’re using invalid or blacklisted product key, you may have to change the Office product key (Guide: How to change Office 2007 product key). This is especially so if you’re using Microsoft Office 2007 Blue Edition.
Disclaimer: This patcher is for genuine Office user who having problem to pass genuine validation only. To use Office 2007, you must purchase a licenseir?t=techgadgetrev-20&l=ur2&o=1. Alternatively, you can use for free OpenOffice.org, an equally good productivity suite.
on Aug 02, 2010 • Computers & Internet
HP LaserJet 3330 will not print multiple copies
Does this happen only with some documents/software? I have a different HP printer (a LaserJet) that does the same thing only with PDFs printed from another program. (This happens with PaperPort and browsers using the Adobe Reader plug-in, for example.) If I open Adobe Reader and then open the document in question, I can print multiple copies correctly.
I hope this helps.
Changing word docs to pdfs worked for a long time op system windows Xp pro w office 2003 Adobe acrobat pro 7 error message the Acrobat PDF server cannot be loaded run installer to re install tryed...
LIbraOffice.org can read and write most office documents. It also has a built in feature to simple save a document as a PDF. It is self contained and does not require additional software to do so. I recommend using this as a replacement to Office 2003.
If not, a one time use for this project should still do what you need.
I can't load quick book 05' I keep getting the same error.
- close all programs
- use internet explorer to open http://www.adobe.com/products/flashplayer/ - download and install flash player.
- run quick book 05 installation again
Can not install quickbook pro 2005 with vista
you need to update your flashplayer. you can do this at adobe.com
Adobe 8.0 Pro corrupts MS Office 2003 Normal.dot file
un-install and re-install office, or get the normal.dot file from other computer and copy it to yours.
Adobe Premiere 6
Bro, I can solve this
The serial you put in is fake or junk...I can fix this by giveing you the whole Adobe CS4 package for no cost....look
Go to www.Myspace.com/KyleGallas to watch a video of a Custom Gaming Computer with Adobe CS4 with the Premiere standard...The PC has like $4,000 retail for like $659. It comes with a ton of extras like 133 Nintendo DS Games, Fallout 3, Adobe CS4, MS Office Ultmate 2007, Roxio Ultimate 2009...and more...Nothing is trial-ware but yours forever.
5helpful
8answers
Office 2007 professional and Adobe 8 Professional problem
Very simple fix. Now and then after an Adobe Acrobat update Office will disable Adobe Acrobat as it is an add on. All you need to do is re-enable Adobe Acrobat. In Office 2007 goto Word Options, Add-ons, and at the bottom of the page is Manage. Click on the down arrow and select Disabled Items and click on GO. Re-enable Acrobat and you should be fine. In Office 2003, goto Help and selects disabled macros and re-enabler Acrobat.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
