Blue tooth by definition should be able to connect between any units that are Blue tooth capable. Make sure the Blue tooth is turned on on both units and both can be identified.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hi, you will need pair both phones together before you can be able to send .
Hi, first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone. You can use this link to see how to flash your phone. (hubpages.com/hub/How-to-Flash-your-cell-phone) and (unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
If you are referring to connecting your pone to your blue tooth device(dongle pluged into your computer?), you activate the blue tooth on your phone, plug the device into youre computer and right click on the blue tooth icon in the bottom right corner which will appear after a few seconds.
Click on ad device, your device will then search for other blue tooth devices. Your phone must then appear. double click on your phone, then you will be asked to enter a password. Enter anything and then next. Your phone should now ask for a password then enter it.
If you have facing some problem while connecting via blue tooth check you these sittings
you phone have name in blue tooth your phone should be visible on And you should one it while connecting to any device then you can search for any blue tooth device.
Let me know if you have any other question regarding this topic.
