Acer Aspire 5602WLMI Notebook Logo
Anonymous Posted on Nov 09, 2009
LAPTOP IS MAKING WIERD SOUNDS OUT OF THE SPEAKER
Hi there. for a while now my laptop has been making a wierd sound. Its coming out of the right speaker and stops when i click mute. When i plug headfones in, the same sound comes out of the right headfone
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Nov 09, 2009
Anonymous
Contributor
Level 1:
Answers
35
Questions
0
Helped
7963
Points
78
Dear sir,
this types of problem come from the sound section of the laptop motherboard. your laptop contains sterio sound system. problem is one channel of the sound circuit faulty. but it is too dificult to repare it.
u can do one think, u can stop one channel sound by using sound balancing option from the task bar volume control option.
also u can contact with Acer service centre.
Testimonial: "Thanks for the help, thankyou for being so quick to respond"
My asus adapter was working fine and now somehow it wont charge. Led on adapter is not going on and adapter makes wierd sound. Dint use adapter couple of days and then it started working again...and now...
My best bet is that the adapter is overheating. I have seen similar issues when I used to do computer repair. As far as I know there is no easy way to fix this besides using it in a chilled environment. Um... other possible problems with the same recomended course of action are: some how a wire got lose inside, a liquid got spilled on it by somebody or something, or it sustained a jarring fall (not likely).
Won't turn over... just makes a clicking sound... and a wierd humming sound.
Try cleaning your terminals at the battery, even if not corroded. In my years as an alarm/radio installer I have come across this problem constantly, especially on GM vehicles.
1helpful
I have a wierd "roaring/whining" noise on my RT.
possibly a rear axle bearing. they do make a roaring and whining sound when driving.
3helpful
Hi my sony vaio vgn cs36gj is frozen and making wierd noises from the fan it frozen on the desktop with the start menu up the desktop has also gone a bit pale also cnt do anything on it it wouldnt even...
possibly yes. this sounds like its overheating and locking up. need to know what operating system you are running and whether you hear the fan running or not
When i use it it makes a wierd grinding sound
Take the computer to a qualified technician, for professional trouble-shooting (failing bearings in a cooling-fan, or a disk-drive about to die).
My Dyson CDC14 Animal just started making a wierd sound coming from the rotating brush area. I already cleaned around the brush, sounds like a fast rattling sound.
Something could be jammed, or not rotating freely, maybe an improper alignment with the brushes, or a blocakage within them. Try to re adjust the brushes :)
2helpful
2004 grand am weird noise
Have you noticed if the noise changes while doing a swerve to the left or right ? If so , it is likely a wheel bearing & will require replacement of the entire hub .
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
