Computers & Internet Logo
Posted on Nov 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No audio to speakers on hp 552w com - Computers & Internet
Jerry Umali
Level 3:
  • Master 979 Answers
  • Posted on Nov 09, 2009
Jerry Umali
Master
Level 3:
Answers
979
Questions
0
Helped
252394
Points
2876
Good day sir/ma'am, hi, If your PC does not produce sound, it could be any of the following so check the list one by one:
  1. Your device driver for the sound is not yet installed. locate the CD that comes with your PC. I could help you find the driver if you add any information about your PC model or motherboard maker, you can download the driver at driverguide.com, just note the maker and model.
  2. Your volume is either in mute or in a low volume setting. Check the taskbar at the lower right side of the desktop, if you see a speaker icon, right click it and set the volume level to high.
  3. Your speakers is not connected to the audio port. Check the baby plug stereo speaker connector for open wires, if the wires are good connect it to the green audio port at the back panel of the PC, (usually pink, blue and green are side by side)
  4. Your speakers are not working properly. If you have portable mp3 players, plug in your speakers to test the speaker unit itself.
  5. Worst come to worst if your green audio port is the defective one. you can use the blue one provided you enable 4 channel, so sound is also sent to the blue port.
  6. your built in sound card is bad, you can get a replacement soundcard of any brand, provided its PCI slot. or get those small USB type sound card.
  7. Check also the BIOS setup, see if the built in sound card is enabled.
If I miss anything feel free to ask, hope these will solve your sound problems.
Why won't my hp elitebook 8540p speakers work while in the docking station, connected only to external mouse and monitor?
You can switch audio playback between the docking station and your Surface speakers. Here's how:
Step 1: Swipe in from the right edge of the screen, and tap Search.
(If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then click Search.) Step 2: In the search box, enter manage audio, and in the search results tap or click Manage audio devices. Step 3: Next, do one of the following:
  • To play audio through the audio port on the docking station, tap or click Speakers (CNXT Audio).
  • To play audio through the Surface speakers:
    • On Surface Pro 2 or Surface Pro 3, tap or click Speakers (Realtek High Definition Audio).
    • On Surface Pro, tap or click Speakers (2-High Definition Audio Device).
Step 4: Tap or click Set Default, and then tap or click OK.
http://globalvision.com.vn/vn/may-in-ma-vach-pc-3.htm
No audio at all ...compaq jbl pro speakers plugged into a hp computer
Reinstall Audio drivers from HP website:
http://www.hp.com/#Support and click on START DETECTION. ü
>comments, suggestions, and ratings will be greatly appreciated.
2helpful
2answers
Can Dell speakers be used with HP computers? I recently purchased a HP computer. Can I use my Dell speakers? I can turn them on and the light comes on, but can get no audio.
Well speakers are speakers so to "Speak" ... As long as the INPUT connections are the same, then, there is NO reason why they should not work.
Diconnected my HP computer for a while and now my BA745 speakers will not work. Suggestions?
Do you try with another speaker, the all one if you hear audio with another speaker the problem was tour hp BA745 if not you need to go to HP.com and download the driver again.. pls download buy hp .com because in other driver sites com with virus and my infect you computer the HP its secure.. That spep resolve you problem,... pls click if my solutios was helpful
Pavillion 552w cant get pass Award BIOS setup utility screen
hELLO THERE
First you will need to check the battery to see if it is low and needs to be replaced.
next boot the machine into bios and make sure that the time and date are set next select fail safe setup or
use the default setting also make sure that the harddrive is being recognized and is being loaded once the post is complete ok?
than save and exit and reboot .
best regards michael
HP PAVILION ze2000 speakers not working
First of all, make sure that the issue is with the Speakers or with the Audio Card of the notebook.
First, download and install the Audio Drivers of the Notebook from the link below :
ftp://ftp.hp.com/pub/softpaq/sp30001-30500/sp30262.exe
Please save the file in the Notebook and double click it after the download completes to install the drivers.
Restart the computer once the installation is completed.
Now, try playing any audio file using Windows Media Player.
If you are not able to get any audio from the speakers, try pluging Headphones into the Headphone Jack of the Notebook.
If you are able to listen audio from the Headphones, the issue is with the Speakers where you need to replace them.
However, if you are not able to listen audio either from the Speakers or from the Headphones we need to suspect the Sound Card.
Contact HP Chat support and find the Part Number of the Speakers if there is audio from the Headphones.
2helpful
Built in speakers will not play any sound
going to seem a dumb Q,
but is the audio cable plugged in, next to vga hp have a separate audio socket, the cable(supplied- 1/8 inch stereo plugs each end) fits between sound card speaker out, and monitor.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00307478&lc=en&cc=us&product=459838&dlc=
Grand Canyon Tech
Grand Canyon Tech
