Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag FAV6800AW won't spin. COuld this be the
Maytag FAV6800AW won't spin. COuld this be the clutch? Washer cycle counts down to 37 minutes, won't go into rinse cycle.
  • 526 Answers
Hello leaweber,
Yes most times it is a Clutch malfunction . Is the machine failing with “dc” and or “UC” unbalance error codes in spin cycle? If you are you may have a Clutch malfunction or Tub Displacement Sensor failure more likely a Clutch issue.
You can do a quick TDS sensor check thru the lid just follow this from the Service Manual. If you machine will pass the TDS check the next step would be to remove the clutch from the machine and inspect as I describe in this post.
Tub Displacement Sensor check from the SM slightly modified;
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 for the details.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you get these results your TDS sensor should be just fine. Time to look at a clutch repair/replacement. Let me know if you need help…. Rich aka dh1200s
Posted on Nov 09, 2009
6ya staff
SOURCE:
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Model fav6800aww drains during the wash and rinse cycle but does not drain during the spin cycle. it give an dc code during the spin cycle which i know that means unbalance but what does that have to do...
Clutch issue and possible time for a tub seal replacement
Google this for a post that covers the Clutch removal and inspection/repair;
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Google this for Outer Tub bearing rebuild;""
FAV6800A/FAV9800A Outer Tub bearing replacement""
Aug 20, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My washer starts the wash cycle, but then will not go into the rinse and spin cycles. What do you think is wrong?
I think you have a clutch problem if the machine is FAV6800A or FAV9800A.
See this post for troubleshooting and a link to the Service Manual 5th post down in the thread.
If you want to troubleshoot open up a new thread in that DIY forum. I can't find my old post on this forum for Clutch Pulley/Outer Tub bearing issues. You need the Service Manual for the next steps of troubleshooting I would take you thru.........Rich
Feb 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Neptune Washer Spin Cycle
If your FAV6800A or FAV9800A wash tub is banging around in Spin Cycle of the Wash Cycle and your Control Board signals a dC or uC error code to the console I feel you have a Clutch malfunction. I feel the TDS is working as designed with the unblance error code shut down.
See my Clutch Fix post for more info related to dC and uC unbalance errors with the FAV6800A and FAV9800A TL’s and the repair action…….Rich
May 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag fav6800aw top loader getting dc code in rinse cycle 12 min.stops and go's back then try's to spin but the tub starts moving all over the place.and then try's again after a while just stops it...
ernieesparza
You have clutch malfunction. Take a look at my Clutch Fix post and see if you can DIY the fix.
Basic hand tools and DIY skill sets is all that is required and you can save your $1K machine. Post back if you have questions or concerns…..Rich
Mar 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Getting dc error code in rinse cycle, 13 min. before being done Have un-pluged and still getting code. Maytag FAV6800 LED washer, 5 years old.
Hello rdberg,
See this post Clutch Fix it has helped a few owners with the dC and uC unbalance errors with the FAV6800A and FAV9800A machines. You have a very common problem with a Clutch malfunction. The first part of the post has to do with the nuts and bolts of disassembly and Clutch maintenance or replacement of the Clutch Pulley.
In the last part of the post I go into just how to check the One-Way Rollers clutches to verify that are locking up. If they don’t this results in tumbler movement on Wash Basket spin up and the unbalance errors. If you are handy and have some basic hand tools you can get your machine back in service at low cost.
Post back if you have questions…..Rich
Mar 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The washer goes through the whole cycle then for the last 11-12 min it stops and doesn't finish the rinse cycle. it sprays water just like at the begining of the cycle then tries to spin then pauses
With no error code on your FAV6800AW or FAV9800AW I will still give it shot. I believe you are failing in spin cycle. See this Post and the post I link to for a step by step clutch maintenance/repair. If you have more info on the failure or questions post back and we will try to help.
Sep 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer doesn't spin
Hello skull1829 ,
Was the Clutch/One-way roller bearing changed out for dc/UC errors in your FAV6800AW/FAV9800AW?
If you start a Spin Only Cycle with an empty wash basket will the wash basket spin up CCW and complete the cycle? Lift the washer top from the base a few inches to observe the wash basket CCW rotation in spin cycle. If the clutch spring is broken or end pins of spring aren't seated the tumblers will rotate and the wash basket will rotate slowly CCW.
IF the wash basket won't spin up can you pull the front cover off and insure the motor will rotate the clutch pulley CCW in a Spin Only Cycle? Let’s try these few basic tests and get some feedback for troubleshooting.
Rich
Jun 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune won't advance from Rinse to SPIN
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(@#$^
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
173 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
