Canon PIXMA iP4200
Every fifth line has a white streak through the text. It looks like the page did not move correctly through the feed or the ink fails to print complete letters.
I would try using something like rubber renew on the pickup rollers and make sure that the paper is being fed correctly. If this is happening then start looking at the ink.
Open the printer and remove the ink. Clean around the ink carriage and
the under the ink with alcohol and a cotton swab. Pay special attention
to areas with copper contacts. Some
printers will let you re-run a cleaning utility from their system menu or the computer printer properties. Keep
in mind too that some printers will not print correctly, even with full ink, if
the exact type of ink it expects you to have is not installed. If all else fails change out the ink, but double
check that the ink is correct against the manual or written
instructions inside the printer. Not every cartridge that fits the
printer necessarily is the right type and using the wrong ink can cause unexpected results.
