Question about Polaroid PoGo Digital Photo Printer
Polaroid Paper Jam
The polaroid blinks a red light which is supposed to mean paper jam, but there isn't a paper jam when i check inside the paper tray. I've tried putting new polaroid photo paper in but it still blinks a red light whenever i send a bluetooth image to it. How do I get my polaroid to print images again?
    New Friend:
I had the same promblem and this is how I solved it. If you have an android, screen shot the picture and crop as you desired. Then Press the share button and click bluetooth (Poloroid Zink) and dial in 6-0-0-0 for the password. Only put that in for the password. If it the password entry doesn't come up, that's okay. Hopefully this helped!
Posted on Aug 18, 2016
6ya staff
SOURCE:
acdr
kishor khatri
  • 1913 Answers
SOURCE: Printer Jams
hi
check your printer that not any paper jam in printer remove it.
also change printer roller.
Posted on Mar 25, 2008
Anonymous
SOURCE: laserjet 4345 mfp paper jam
13.20.00 can be also caused be a jam near the fuser (the part of the printer that gets hot to make the toner stick to the paper). Remove the toner cartridge and take a look for small scraps of paper along the whole path. Also open the door on the back of the printer and look for paper scraps from there. If you see paper stuck in the fuser, do not use anything sharp to remove it, be careful not to scratch the surfaces.
Posted on Oct 08, 2008
Andy
  • 44 Answers
SOURCE: oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Posted on Apr 18, 2009
Anonymous
  • 14 Answers
SOURCE: my polaroid pogo wont print
when printing make sure that the paper is inserted in the pogo shiny side up and logo facing down. also try putting through the blue alignment sheet first as the pogo will not work without this. hope this helps
Posted on Oct 30, 2009
asood23
Amit Sood
  • 200 Answers
SOURCE: whats the polaroid passkey for bluetooth?
The passkey is either 0000 or 1234
Posted on Dec 22, 2009
Why does the data light blink then paper jam light goes on even with no paper in it
Most likely when you removed the paper jam a small piece of paper got jammed under one of the sensors. This is a very common problem. It is also possible depending on the model that you have dislodged one of the flags that activates sensors for paper travel. Check the back of the printer in the fuser area as these are the most commonly damaged sensors.
Sep 04, 2014 | Lexmark E Office Equipment & Supplies
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
Go to print and status say paper jam, checked rollers and inside, but no jam
i lost my cd of Hp Deskjet F380 and i want to install now to my cp, secondly it use to show me red light blinking saying paper jam while there is no paper jam inside the printer for now she is not working
Nov 23, 2009 | HP PSC 1210 All-In-One InkJet Printer
Kyocera FS-920 RED LIGGHT IS BLINKING AND GREEN LIGHT IS OFF
There are 2 possibility to cause your printer acting like this:
1) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
2) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
If it is condition 1) then just remove the jam paper then open and close the Top Cover to clear the error.
If it is condition 2) then insert some paper in the paper tray.
YBC (/\)
Jun 05, 2009 | Kyocera FS-920 Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
CANON I960 BLINKING RED LIGHT 2TIMES
is the piece of paper removed? or there parts of the paper w/c was nt removed? if the whole paper was removed already, try to use this steps..step 1. remove the power cord of the printer. step 2. press the power on/off of the printer while plugging the power cord. and wait for 10 seconds before releasing the on/off button..then put on your printer. but if some pieces of broken paper inside the printer try to clear it first then try printing.
Jan 02, 2009 | Canon I960 InkJet Photo Printer
HL 2040 paper jam light is blinking but there is no jam. the printer sounds like it dies out everytime it tries to print.
Often the paper jam light will stay on when the *back* paper jam door is not cleared.
Open up the back of your printer. There is a 2nd door behind this door that you can pull open. If there is a paper in this section, pull it out and it should clear your red light.
When clearing paper jams, clear the front first, and then if the red light is still on, you need to check the back hidden door for another piece of paper.
Dec 08, 2008 | Brother HL 1440 Laser Printer
Printer Jams
hi
Mar 25, 2008 | Polaroid PP46d Thermal Photo Printer
Printer problem
hi, Take out the toner and check for a paper jam.turn the printer upside down and check under the paper tray for a jam. When you reset the printer check to see if the printer picks up the paper, if it tries to pick up the paper then the red light flashes you should rough up the roller on the front above the paper tray, the rollers sometimes get smooth and won't pick paper up. You should also look inside where the toner cartridge goes and there are some little plastic flaps.Check that these are not stopping the paper going it. hope this helps
Sep 25, 2007 | Brother HL-2040 Laser Printer
Polaroid PoGo Digital Photo Printer Logo
3,418 people viewed this question
Top Polaroid Office Equipment & Supplies Experts
Ekse
Joaquim Martins
Clive
Clive
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
